1Step 1: Solder the Switch and the Battery Holder
The design on this board is super simple so you can solder the components on in any order. Personally, I like to start with the switch and battery holder. I made the holes for the battery holder snug so with a little pressure it should snap into place for easy soldering!
*Note: When soldering the battery holder be carful not to get solder outside of the pad or the board will short!
If you're having trouble keeping the board from moving when soldering you can use a piece of tape to hold the board down. Just be sure not to have the tape too close to where you are soldering your joint!
*Note: The battery holder and switch are made of metal so they get hot when soldering. Be careful touching them during and directly after soldering!
*I like to add a bit of extra solder so the clouds eyes look nice and smooth.
2Step 2: Solder the LEDs
Insert LEDs up to the little notches then bend into a right angle. Repeat this step for all the LEDs then solder into place
3Step 4: Insert Battery and Enjoy!
Your Sunny Surprise is complete!
