1Order PCBs at your Favorite PCB Manufacturer
Download Gerber Files here... zip them and upload them to your favorite PCB maker
https://github.com/Uspizig/EinkKeyboard/tree/main/GerberFiles
If you want to change stuff: You may find complete KiCad files as well here:
2Wait for PCB Arrival
Klick this Video to shorten the Time: Link
And buy all the parts listed
3Solder the bottom side of the PCB Board First
The most difficult part to solder is on the bottom side the eink connector.
If you never soldered such fine stuff with 0.5mm ask someone for help.
The first step to solder is the EINK Part This should look like this:
4Solder the front side
Start first with the ESP32 and the programming connector.
Try to check with one led if everything is working.
5Add the Power Supply Part and check weather it is working
Time to add the rest of the parts
Your finished board should look like this.
Ulrich
