The 3D Slicer is perfect to show the output images for the doctor´s diagnostic. However, there is a couple of things:
1) 3D slicer works with 2D images. It can use plenty of file formats, but again, 2D images.
2) CT systems does not produce images, it delivers Projections.
In this scenario, i need take the data collected from Gantry ( Detector), and translate to 2D images for use in 3D Slicer. To do the first part, i will Reuse this board:
This is an old 8 bit Frame Grabber that i got, and i had used into another past projects. As you can see, this board has a ISA BUS. This is itself a challenge, because i need to put in working condition the board to capture the projections.
