Well.... some time without posting here. When things needs detail, speed goes down.
I had the chance to support a Dicom Viewer Station, implemented with an Imac PC.
![](https://cdn.hackaday.io/images/2160251664466127830.jpg)
A project log for CT system Revamp
The most probable failure to decommissioned a system is Image Processing Unit Hardware. Here a way to Rescue it, using Open Source solutions
