Body1.stlOriginal file from pashiran: https://www.instructables.com/Motorizing-an-IKEA-SKARSTA-Table/This will be screwed into the table and the case comes on top of it. Some M3 insert nuts need to be soldered into the filament. Standard Tesselated Geometry - 323.52 kB - 06/12/2022 at 18:13 |
ideaMaker_print_settings.binPrint settings template for the ideaMaker slicer.octet-stream - 23.98 kB - 06/12/2022 at 18:11 |
case_with_HC-SR04_holes_.stlCase (top part) for the electronics. Has two holes for the ultrasonic sensor.I printed with 5% infill, 0.3 mm layer height, 1.4 shells, print speed 80 mm/s. This print took 7 hours and 24 minutes. Standard Tesselated Geometry - 212.68 kB - 06/12/2022 at 18:06 |
