Compile and upload the software to the board by clicking the upload button
Visit the web dashboard
Get the IP address: The board should've logged into your WiFi network after you have uploaded the software. You might want to open the Serial Monitor to know which IP address was assigned to the board. Othwerwise you can also download a smartphone app i.e. "Fing" to scan all the IP addresses in your local WiFi network.
Open the hosted website in your browser: i.e. in the browser address bar: 192.168.1.137
Should look like this
Optionally set a domain name in your WiFi router etc.
If everything is working, you can disconnect the board from your computer and assemble the system to the table. Also make sure to use a power supply for the board.
