WW27: Chassis welding and painting
07/07/2018 at 20:13 • 1 commentChassis after welding and with primer
Painting first black layer. Need another one, and some finish.
WW27: BrainfuckPC is 60% Done
07/02/2018 at 20:22 • 2 commentsSoldered:
- Switch modules 8/8
- Indicator modules: 4/4
- 2AND/2XOR modules: 32/32 (And Fully testes Adder is Wire-Wrapped)
- D-trigger modules: 64/70
- 2AND/2OR modules: 13/22
- 2& Modules: 14/58
- Diode modules: 6/10
TODO:
- Base boards wire-wrapping
- Chassis assembly
- Blocks interconnection
WW25: BFPC Chassis parts done! It so huge...
06/21/2018 at 07:19 • 0 commentsMy friends from Moscow made BFPC chassis parts using laser cut and sent it to me. I had to redraw it to 2mm Al, because 6mm Al is toooooooo heavy(about 5kg) and expensive.($500).
This model is lighter than one kilo and I spent only $80 to made this.Other four parts
BrainfuckPC MIDI input improvements
05/21/2018 at 07:20 • 0 commentsI found how to catch midi events more correctly, so now Midi-grabber can understand short key press and movement to another note while current is not yet released.
Just need to learn play a piano :)
BrainfuckPC Testing MIDI input
05/19/2018 at 19:11 • 0 commentsI took MIDI keayboard and created simple app for catching NoteOn packets and generating square signal for sending CarryIn to Adder (that's all what I can do right now).
WW18 BrainfuckPC 3D Model
05/04/2018 at 22:28 • 0 commentsI started making BrainfuckPC base plate and for doing that I need full 3D model of PC.
I created all blocks with different assumptions. It's a final blocks arrangement! Final dimensions are 1000 x 650 mm.
Base plate - Aluminium 6mm. Work is in progress, so you can check current model state on Autodesk site here: https://a360.co/2rnFQnh
WW17 Indicator module 3D-printed rack
04/29/2018 at 19:09 • 0 commentsDraw and printed indicator module rack. I need four of them.
Need to paint black internals and install colored glass
White HIPS plastic.
3D model in Fusion 360
WW17 16-bit switches kit
04/29/2018 at 19:05 • 0 commentsAlmost done with 16-bit switches - just need to solder connectors on some of them.
Each contain 8 reed soviet relays RES43 and set of LED's on each side.
WW16 BFPC Project overview [ENGLISH]
04/17/2018 at 08:01 • 0 commentsCreated show video-review of my project for hackaday Prize 2018 Contest
WW12 Worlds-Fastest Relay Adder Test - 500OPS
03/22/2018 at 07:21 • 5 commentsInsane five hundred ADDC operations per second to the relay!
0x9999+0x6666 + Carry = 0x10000 with Carry and 0xFFFF w/o it, so All digits are involvedWorld-Fastest relay adder exist - Time to go to the worlds-fastest relay computer
