Finished
10/23/2022 at 00:57 • 0 commentsAdded the wooden base and fisished the assembly
The two pictures below shows the auto brightness adjustt, comparing to the Paganini clock (in ultradian mode).
Homemade PCB
10/17/2022 at 06:11 • 2 commentsI have built a PCB at home using toner transfer method
The board was assembled and I have a first release of the code uploaded in github![]()
As the display is placed on the bottom the board provides holes to solder bare wires that are wrapped on the display pins.![]()
