This is the new parser code mentioned in the logfiles. A significant number of commands have been added compared to the original code. Still no README file, but this builds with the instructions in the text above. Fixed some un-initialized variables in parse_and_exec.c that were preventing the low level device functions from being called. Strangely, the previous code worked fine on an older version of the C compiler and did not generate warning messages with the newer version. This should still be considered Alpha code until I get a lot more miles on it.
Fixes for error detection and handling. Added command for setting scope clock to match PC clock and displaying a short text string at the top of the scope screen. Has notes (aa_notes) on how to build for MINGW environment and how to build for Linux/unix environment.
This file contains the changes to facilitate building this tool for the 54522 or 54520 scopes. It also has changes and instructions to allow building this tool in a MINGW/Windows environment. See the aa_notes file for details.
