This zip file contains the source code to build my HP54542_ctl utility under Linux/Unix and the open source parts to build under Windows. The Windows environment needs a couple of National Instruments files that come with the NI488-2 driver package, and one Microsoft file CHKSTK.OBJ. See the previous log file for discussion on how to build.
While working on a library for another instrument (HP5334A freq counter), I realized that the error detection that I had after each GPIB transaction was not working correctly. After some cursing and thrashing (and testing), I believe it is correct now. I updated the code in this zip file.
2 new commands, one to set the clock in the scope to match the one in the PC, and another to put a short text string on the screen of the scope which is useful for annotating scope shots.
