Swapped out the Command Parser and added a lot of commands
A project log for HP545xx Data Acquisition Software
A software tool to use an HP545xx Digital Scope for Data Acquisition
bharbourBharbour 09/23/2023 at 19:070 Comments
When I wrote the original version of this tool, I used a very simple command parser. I knew that it was not very scalable, so adding commands would get ugly. I have written several command line control tools for other instruments since this one was done, and I arrived at a parser design that I like.
In a fit of boredom during a long, hot summer, I swapped the original parser out for the newer one. I also have added a bunch of commands. The new version of this tool has enough functionality to control a big part of the stuff I use this scope for.
The code is still very much Alpha stage code, but if someone is interested in it, leave a comment or PM me and I will get back to you. The amount of new code means that it is going to take some time to get all the issues worked out on it.
**** 2025 Note, the source code is in the files section now.
The command set on this scope is truly huge. I probably have only implemented 1/4th of it, if that much.
