21 Band Audio Spectrum Analyzer
Completed
Public Chat
21-Band Audio Spectrum Analyzer using ESP32 controller together with a set of three MSGEQ7 ICs for the 21 frequencies and 21 strips of 20 LEDs WS2812B for a total of 420 LEDs. Audio Amp and Bluetooth are optional.
This project started as a hobby using a generic 14-bands spectrum analyzer based on Arduino AT-Mega, and converting it to a 21-bands audio spectrum analyzer now running on ESP32 with more memory for additional color patterns and features. New hardware includes the low cost 2x 3watts Audio Amp and Bluetooth connectivity.
The biggest challenge was making the LED bezel / 20x 21 LED array. I ordered separate vertical columns for the LED strips to stick on, and then solder the two ends to 3-pin terminals. I also ordered the 2 horizontal PCBs that holds the 21 columns and distributes power to all 420 LEDs .. Using the LED Strips with the PCB was the easiest way I could think of without having jumper wires between the 21 columns ..
A second variant, which I will try in the upcoming weeks, is to hand solder the 420 LEDs individually which will save me about $40 and will look much nicer. I will try and use low temperature solder paste (138degC) and a heat gun to blow hot air from below the PCB. I'm not sure is going to work, but using a hot-plate will be even more challenging.
Gerber_21-Bands-Audio-Spectrum-Analyzer-Simp_PCB-21-Bands-Audio-Analyzer-Simple_2025-10-30.zip
Artwork Files. Order boards at: jlcpcb com
x-zip-compressed - 200.85 kB - 10/30/2025 at 22:22
Download
Spectrum_Analyzer_21x16_Red_ESP32.zip
SKETCH in Arduino IDE - using a 21 x 16 matrix display panel.
x-zip-compressed - 1.41 MB - 10/30/2025 at 22:19
Download
Spectrum_Analyzer_21x20_Red_ESP32.zip
SKETCH in Arduino IDE - using a 21 x 20 matrix display panel.
x-zip-compressed - 1.36 MB - 10/30/2025 at 22:17
Download
Assembly Drawing
Portable Network Graphics (PNG) - 249.26 kB - 05/24/2023 at 03:34
Preview
Schematic_21Ch Analyzer ESP32 - Full_2023-05-14.pdf
Schematic Diagram in PDF
Adobe Portable Document Format - 142.44 kB - 05/15/2023 at 00:52
Preview
View all 7 files
  • 1 × ESP32 38pin Type-C Dev-board Expressif
  • 1 × Si5351 Skyworks Clock generator - SparkFun
  • 3 × MSGEQ7 7 Band Audio Spectrum Analyzer IC
  • 1 × M18-HX8 Bluetooth - OPTIONAL
  • 1 × PAM8403 Audio ICs / Audio Amplifiers - OPTIONAL
View all 22 components
View all 2 project logs
  • 1
    Order your parts and wait 3-4 weeks.
    1. Order boards JLCPCB.com (black soldermask finish).
    2. Order parts AliExpress or Amazon and for MSGEQ7 go to Mouser.com to avoid fake ICs.
    3. Order LED strips from BFT-Lighting.com or whatever works for you but be consistent. Do not mix and match or you get some weird colors from different suppliers. (I got 5 rolls of the 74/m black IP30 for about $65).
  • 2
    Solder components to the board top side.
    Solder smaller components first such as the ceramic caps and resistors. Resistors R5, R6, R7 and R8 are only needed if you plan on adding buttons for the Bluetooth such as next / previous.
    Also don't solder C17 and R9 (only needed for internal clock single 7 channel mode). Next solder the larger electrolytic caps with polarity markings (C12, C13, C14, C15 will be soldered axially on a 90 degree angle). Mount and solder Jacks J1 and J2, will come handy if using a 3.5mm audio line input.  For U0, U1, U2 it's up to you if you want to use an 8-pin DIP socket for mounting the MSGEQ7 ICs. Complete by soldering the rest of the parts.
    Here is the Assembly Drawing (top side).
  • 3
    Ignore the parts on the board bottom side.
    The bottom side components are intended for advanced players. Mainly if you intend to mount everything in a housing resembling a portable speaker, in which case having the extra batteries might come in handy. Use a 2-pin jumper on header Bypass the charging circuit and power directly from 12v. Also make sure header 'ON' gets a jumper if you want the LEDs to come on.
View all 7 instructions
meuviolino wrote 07/01/2026 at 22:12 point
Hi Sam! First of all, thanks for sharing your excellent project. I have a few questions:
1) I’ve never placed an order with "jlcpcb.com" before, so I’d like to know which file from your project I should upload to have the boards manufactured.
2) Inside the "Gerber_21-Bands..." zip folder, there are 11 files; do they know which ones to use, or do I need to specify something? (Should I upload the zip folder itself?)
3) Does the content of the Gerber folder work for both projects—"Spectrum_Analyzer_21x20_Red_ESP32" and "Spectrum_Analyzer_21x16_Red_ESP32"—or do you recommend using the "21x20" version?
4) Instead of 20 LEDs vertically, I’d like to use 10 LEDs—specifically 5 Green, 3 Orange, and 2 Red, from bottom to top; is it possible to change this in the code?
Sorry for so many questions. Thank you very much.
Sorry for all the questions. Thanks a lot.
Daniel - from Brazil
TM Russell wrote 07/02/2025 at 02:15 point
I plan on making this one! I already ordered the pcb's. I love how you laid all the boards out, that was clever. The only thing I wish you had done would be to make the front controls on a separate pcb for easier mounting, but its not a deal breaker. I can wire the on/off switch to the front. Thank you for sharing this awesome project!
Sebastian.Anantham wrote 10/31/2023 at 13:51 point
Very nice and hypnotic spectrum analyser
