Internal Battery Mod for Korg NTS-1 Synth
Back to overview
Integrate an internal battery in your Korg NTS-1 to make it the perfect portable synth
Adam Hougham wrote 11/17/2022 at 13:57 • point
Thanks for posting this mod - I've just got the NTS-1 and am wondering about doing something similar to you with a battery.  I see on the board next to the speaker are a bunch of labelled pins including ground and 5v that might be a good place to hook up a switched battery? It might then be possible to disconnect the power lines from the original USB port so it only functions for PC / MIDI connectivity? Also interested to see the pins in the same location marked 'MIDI out'  and wondering how/ where to add this!
