should I Tindie / eBay this?
01/27/2017 at 13:41 • 1 commentI'm seriously considering to fix the minor problems, make another batch and sell them. Here are some thoughts and questions.
- it's simple to understand
- easy to integrate into projects
- it's different enough from the original LCD modules
- parts are affordable, which keeps BOM small
Design considerations
- should I add a controller for the RGB led?
- should I connect via SPI or I2C?
- I2C: more pins on the header, Attiny possible
- SPI: too many pins for attiny, LED pin reusable as CS
- or even use WS2812b protocol
- LED pin reusable as DIN
- requires timey-wimey stuff
- get attiny or original controller chip
- leave it as is, use 2 extra pins, let the customer worry
- design pinout like sparkfun, adafruit or cheap eBay boards?
- idea here is to make it easy to swap
- keep it 5V?
Pricing
could be around 10 Euros and still have a good margin.
one board is soldered
01/25/2017 at 23:07 • 5 commentsNotes:
- definitely order 0.8mm boards (I failed because it was after midnight... )
- pins for display can be shortened by shield -> edit footprint!
- 5V stuff is confusing! I only considered it for getting more "bang" for the buck
- next version should have Attiny13 for I2C RGB control
- maybe add an ESP12 foot print
- play with MQTT (red alert / temperature stuff)
- also RGB pinout is not correct!
- resistors for colors are not in the same order and values must be corrected
- ESP12 analogWrite has 10bit resolution!
there's another display in town
12/01/2016 at 11:24 • 2 commentshttps://catmacey.wordpress.com/2013/08/08/breakout-board-for-nokia-1202-lcd/
It's a Nokia 1202 display, having a whopping pixel resolution of: 96x68
where the Nokia 3310 has merely 84x48
fun with eBay
11/29/2016 at 18:49 • 3 commentsThe first display from eBay came the other day and these are the winning pictures that got me a second one send to:
No boards here yet, so it doesn't hurt. Well it does hurt seeing those monstrous scratches. Two other displays with pcbs arrived as well, no scratches and with a protecting foil.
