Architecture: 8051
Microcontroller: Silicon Labs C8051F850-C-GU
Toolchain: Keil c51*
The 8051 processor is a popular architecture and Keil provide a comprehensive development environment allowing for simulation and in-system debug.
The approach is to implement a feature, optimise code size as much as possible and if it fits in less than 1KB repeat. At present these features include...
- Enable UART for debug
- Enable ADC
- Enable PWM
- Control PWM duty cycle from ADC input
- Implement PID controller
- Working boost convertor
- Working buck-boost convertor
- Implement constant current mode
- Digital (UART/SPI) interface for user to control voltage/current
- Change diodes to FETs switched by the microcontroller to improve efficiency
* The compiler limits machine code generation to 2KB (not a problem) however it also limits the use of memory less than 2KB by always jumping to address 0x0800 and then continuing with compiled assembler.
Ashley Robinson
Vítor Barbosa
BunneyDude
Jithin
BTW you can also use a SEPIC buck-boost converter - basically a boost converter with an additional capacitor and inductor.
https://en.wikipedia.org/wiki/Single-ended_primary-inductor_converter
