1Get source code
Get the working code from https://www.hackster.io/Shubham_Desai/arduino-endless-run-game-using-lcd-display-push-button-3db715?fbclid=IwAR1UbUjjOFh146SRlP_0eEKIsvp7UL7NTLHGcBHAuJGLjxBLTXIs5f6kJnk
and do necessary modification in the code. The working code for BW16 can be found under Files.
2Connecting between BW16 and I2C 16x2 LCD
BW16 wiring connection
3Final Result
Upon uploading the code to BW16, you can start to play the game and "burn" button can be used to control the "human".
