Joytostick_TRINKET_M0_v2.inoThis code is for Adafruit Trinket M0It's a mix of DIY MPU-6050 Joystick https://www.instructables.com/DIY-MPU-6050-USB-Joystick/ Pin_Joystick, code written by Pin Chung and joystick_simple, code written by gdsports https://github.com/gdsports/xac_joystick_tinyusb/blob/main/examples/joystick_simple/joystick_simple.ino Set Up arduino IDE, see ADFRUIT's Trinket Information and follow instructions https://learn.adafruit.com/adafruit-trinket-m0-circuitpython-arduino/arduino-ide-setup Download and install theses libraries to the arduino IDE: MPU6050_tockn by tockn https://github.com/Tockn/MPU6050_tockn XAC Joystick Library for Adafruit TinyUSB by gdsports https://github.com/gdsports/xac_joystick_tinyusb Be sure to set the USB Stack to TinyUSB. Upload the sketch on the Trinket ino - 2.99 kB - 11/07/2022 at 12:39 |
Joystostick functional block diagram.jpghttps://cdn.hackaday.io/files/1866787986831552/base%20B_5%20mm%20hole.stlJPEG Image - 81.58 kB - 10/21/2022 at 13:39 |
Joytomouse_TRINKET_M0_v2.inoThis code is for Adafruit Trinket M0Remix from the code written by davy : Mouse for people With Brain or Nervous Injuries https://www.instructables.com/Mouse-for-People-With-Brain-or-Nervous-Diability/ Download the MPU6050_light library in the library manager of the arduino software. Upload the program to the Trinket. ino - 1.92 kB - 10/20/2022 at 14:11 |
Joytomouse functional block diagram.jpgJPEG Image - 70.76 kB - 10/21/2022 at 13:39 |
base A_6.4 mm hole.stlEnclosure base for wheelchair with a 6.4 mm diameter joystick barStandard Tesselated Geometry - 163.17 kB - 10/18/2022 at 10:08 |
base B_5 mm hole.stlEnclosure base for wheelchair with a 5 mm diameter joystick barStandard Tesselated Geometry - 165.32 kB - 11/03/2022 at 08:58 |
top_joystick.stlEnclosure top with standard joystick handleStandard Tesselated Geometry - 293.54 kB - 10/18/2022 at 09:59 |
top_ball.stlEnclosure top with golf ball handleStandard Tesselated Geometry - 524.01 kB - 10/18/2022 at 09:59 |
top_flat.stlEnclosure top flat with no handleAdd one handle fit user need Standard Tesselated Geometry - 108.97 kB - 10/18/2022 at 09:59 |
BOM.odsBill of material necessary for Joytojoyspreadsheet - 4.24 kB - 10/21/2022 at 13:36 |
Joytojoy electronic schematic.pdfAdobe Portable Document Format - 13.43 kB - 10/21/2022 at 13:46 |
Joytojoy_PCB.zipThis folder contains the necessary files to create a PCBx-zip-compressed - 51.55 kB - 10/18/2022 at 09:50 |
adafruit-trinket-m0-circuitpython-arduino.pdfManual for the Microcontroller Trinket m0Adobe Portable Document Format - 14.44 MB - 10/20/2022 at 14:21 |
SEN-MPU6050_Manual_2021-11-04.pdfManual for the IMU SEN-MPU6050Adobe Portable Document Format - 1.04 MB - 10/20/2022 at 14:21 |
B3F-1000-Omron.pdfData sheet for switches Round Tactile ButtonAdobe Portable Document Format - 484.45 kB - 10/20/2022 at 14:21 |
Joytojoy_prototype_v1.zipThis folder contains the necessary files to create a Joytojoy v1 without a PCB :- 3D models - software (joytostick and joytomouse) - eletronic schematic x-zip-compressed - 269.67 kB - 11/03/2022 at 09:00 |
Julien OUDIN
