1Select the design fit to your needs
The enclosure is made of two printed parts (base and top) wich will clip together .
Select the right design, fit to your needs
- WHEELCHAIR COMPATIBILITY
For a 6.4 mm diameter joybar = Power wheelchair with Rnet or PRIDE electronic : Permobil, Ottobock, Sunrise, Levo.
select : base A_6.4 mm hole.stl
For a 5mm diameter joybar = Power wheelchair with Linx electronic (Invacare)
select : base B_5mm hole.stl
- HANDLE
For standard needs (standard joystick handle) : select top_joystick.stl
If you need a ball to facilitate gripping select : select top_ball.stl
You can also design a specific handle adapted to your need (ergonomic, esthetic) and mix it to this base : top_flat.stl
2Print the 3D parts
Material :
We use ABS on a Zortrax M200 for its resistance and its functional prototyping properties.
It should work well with other plastic types, depending of the 3D printers you use.
For a standard print, we have good result with this parameters :
Infill = 30 % of
Layers thickness = 0.19mm
No support added
Printing time : 3h48
Material usage : 14.6 m, 35g
3Electronic assembly
- Bring together the different components
- Individually prepare the components :
Solder headers on the trinket m0
Cut off the four no use headers of the SEN-MPU6050 ( XDA, XCL, ADO, INT)
Bend the four headers (VCC, GND, SCL,SDA) at a 90 degree angle
- Insert the components on the PCB, following one board printed indications
Switches
MPU6050
Trinket M0- Soldering
Turn the PCB
Solder the different components pins
Cut of the excess lenght of the pin
4Mechanical assembly
Place button caps on switches
Insert PCB onto the enclosure
Place the top part on base part
Push it to clip the two parts
5Programming
Select the right program either you need a game stick or a mouse :
- For a game stick :
Select the arduino sketch in the files project : Joytostick_TRINKET_M0_v2.ino
Set Up arduino IDE, see ADFRUIT's Trinket Information and follow instructions https://learn.adafruit.com/adafruit-trinket-m0-circuitpython-arduino/arduino-ide-setup
Download and install theses libraries to the arduino IDE:
MPU6050_tockn by tockn
Joystick Library for Adafruit TinyUSB by gdsports
Connect the usb cable : Micro B Male on the Trinket and USB 2.0 Male in the PC
Be sure to set the USB Stack to TinyUSB
Upload the sketch to the Trinket
Check it proper functionning by using Gamepad tester website.
The values corresponding to AXIS 0 and AXIS 1 will vary according to the movements of the device, it means it works.All that remains before playing is to install the box on a wheelchair controller
- For a mouse :
Select the arduino sketch in the files project : Joytomouse_TRINKET_M0_v2.ino
Download the MPU6050_light library in the library manager of the arduino software.
Upload the program to the Trinket
We can check its proper functioning by connecting the joystick to a PC (windows, linux, MACOS, or a smartphone)
The device is recognized as a mouse device and works without further manipulation. The movements of the box move the cursor on the screen and the buttons correspond to left and right clicks.
Julien OUDIN
