M.2 SATA to 44P IDE Adapter
A JM20330-based adapter to use M.2 SATA SSDs in place of 44-pin IDE DOMs and 2.5" drives.
Many older thin clients and embedded devices use a non-standardized format of IDE flash storage known as a Disk On Module, or DOM. These often use the same interface as 2.5" IDE hard drives, but with a smaller footprint and slightly different connectors. Replacement modules are typically expensive and low capacity, and existing adapters that fit in a similar footprint use memory cards like SD or CF, which suffer from poor random access speed and questionable endurance.
This project aims to allow fast and relatively inexpensive SATA M.2 SSDs to be used in these older devices. With the correct connector, it should also work in place of 2.5" IDE drives.
(Note that this adapter is 44-pin IDE. It won't replace 40-pin DOMs or 3.5" drives, as those use a 2.54mm pitch and separate power connection.)
Bill of Materials
Reference(s) Qty Value Package
R1 1 470 0402
R2 1 37.4K / 1% 0402
R3, R4 2 12K / 1% 0402
R5, R7 2 100 0402
R6, R8, R10 3 10K 0402
R9 1 1M 0402
C1 1 47uF 1206
C2, C14, C16, C17 4 1uF 0402
C3, C18, C19 3 10uF 0603
C4, C5, C10, C11, C15, C20-C22 8 100nF 0402
C6-C9 4 10nF / 10% 0402
C12, C13 2 10pF 0402
D1 1 LED 0603
FB1, FB2 2 100-450 Ohms at 100mHz 0603
U1 1 JM20330 LQFP-64
U2 1 RT9059GQW DFN-10 EP
U3 1 MIC5305-1.8YML DFN-6 EP
Y1 1 25MHz +/- 50ppm 4 pin 2.0x1.6 mm
CN1 1 2mm pitch 2x22 header
CN2 1 TE 2199230-3 or 2199230-5 or 2199230-1
Notes/Alternatives:
SATA to IDE Rev 1.1 (with license).zip
PCB files and schematic. Rev 1.1 has some very minor changes from the prototype I tested, mostly with the silkscreen. (edit: Added license file)
x-zip-compressed - 1.20 MB - 10/12/2022 at 00:45
Download
JM20330 EVB-002-3.kicad_sch
Schematic of the official JMicron evaluation board
kicad_sch - 203.43 kB - 10/04/2022 at 00:44
Download
  • First Test Results
    loudaslife10/02/2022 at 00:15 0 comments
    After assembling revision 1.0 of my adapter, I tested it in a Wyse V10L thin client. Surprisingly, it worked perfectly on the first attempt. With a bit of tinkering on the host and drive settings, this was the performance I got:
    The Kingston SSD was a $12 ebay purchase, probably salvaged from a Chromebook. Because the drive speaks SATA to the JM20330, it shows up as a SATA device in most disk info utilities, even though the OS sees it as an IDE drive.
    For comparison, this is how the same SSD benchmarks in AHCI mode on a SATA III port in a modern system:
  • JM20330 Reverse Engineering
    loudaslife08/14/2022 at 01:40 0 comments
    The central component of this project is a PATA to SATA bridge IC. Unfortunately, there doesn't appear to be any suitable chip with (officially) publicly available documentation, so figuring out how to use them can be tricky.
    The most common IC for this purpose is the JMicron JM20330. It's been used in other open source hardware projects, and can be purchased in small quantities relatively easily (though you won't find it on DigiKey or other reputable distributors.) You can even find a leaked old revision of its datasheet with some googling. However, the datasheet only gives limited information on the supporting components required. To fill in the gaps, I purchased what appears to be the official product evaluation board, the JM20330 EVB-002-3 "Host Bribge" Adapter.
View all 2 project logs
Victor Hugo wrote 10/05/2024 at 01:01 point
Hello, thank you very much, I'm designing a PCB (I'm a beginner) for the PS2 slim HD mod, and your schematics were essential for me to do it.
I have just one question though, on the schematics the operating speed is determined by MODE 1 and MODE 0, but the settings are ignored if FXDMA is connected to ground, but in that case what speed does it operate?
spotopolis wrote 03/14/2023 at 15:44 point
Im a total novice when it comes to PCB designs. How difficult would this be to adapt this project to fit the 40pin IDE connector and add a JST PHD (model S12B-PHDSS) header for power? This could be a perfect solution to a project I am working on rather than trying to develop my own custom IDE to SATA adapter where the IDE connector is extended by 1.25in and at a right angle and uses the JST header. This project would allow for a much smaller footprint.
PanciO wrote 02/14/2023 at 06:37 point
Hi, It's very interesting project... I'll  try to use it to connect Retro 8-bit computer to SATA drive :-)
Thanks!
powiadam.ci wrote 10/04/2022 at 21:01 point
Please add replacement firmware to your project
for example some people need hardweare encrypt whole disc or compressing
loudaslife wrote 10/04/2022 at 21:14 point
I'm not sure what you mean. The JM20330 doesn't have any firmware, as far as I know.
powiadam.ci wrote 10/05/2022 at 09:09 point
So far it doesn't, but it may have.
I gave an example of application. Disk hardware encryption. Adding this functionality is not difficult I think.
Corscaria wrote 04/01/2023 at 14:18 point
SATA bridge chips are not programmable, they perform a single function translating SATA to PATA and back. If you want encryption you are going to have to implement it in software.
