Project idea and description
To be as flexible as possible in the use of LoRa-Phy(MAC) we have developed a simple MQTT2LoRa bridge in modern C++. Messages sent on a specific MQTT topic are subscripted by the bridge and sent via LoRa payload. Conversely, frames received via LoRa are published on another MQTT topic. Thus we are able to connect more or less any application in high level language to a LoRa network without having to deal with hardware related SPI protocols. These hardware related things are done in this case by our bridge in C++.
The bridge idea developed based on the idea of combining a simple text messenger with LoRa technology. For example, we wanted to be able to send and receive IRC chats, matrix chats, etc. (pure text messages) over long distances. However, the development of this bridge showed that the potential is much higher. Prototypes for various applications can be developed very quickly, e.g. GPS loggers written in Python via TTN or weather balloon trackers.
GPS logger application
In the case of the GPS-Logger, an application written in Python reads the current position of the GPSd service in Linux every second. Every 60 seconds, the currently read position is then formater encoded via TTN packet and published via MQTT, so that this message can be sent through the bridge.
Dominik Kuhn
Alexander
Chris Low
Daniel Mahony
