After making the circuit diagram I transformed it into a PCB design to produce it, to produce the PCB, I have chosen JLCPCB the best PCB supplier and the cheapest PCB provider to order my circuit. with the reliable platform, all I need to do is some simple steps which we will talk later.
Related Download Files
As you can see in the pictures above the PCB is very well manufactured and I’ve got the same PCB assembled with all the components that we want to use for our main board and all the labels and logos are there to guide me during the soldering steps. You can also download the Gerber file for this circuit from the download link below in case you want to place an order for the same circuit design.
3
Place All the Components on PCB and Solder It Properly.
Soldering the components to PCB.
4
Making Custom PVC Designed Body.
Designing and moulding body.(Dimensions as per your requirement).
5
Sticking Diffuser Sheet and Led Strip.
Sticking Diffuser Sheet to the Custom Designed PVC body And Led Strip to Base Plate.
6
Soldering Remaining Connections & Enclosing the Body.
Now solder the terminal wires from LED, Battery, and Solar panels. The polarity is marked on the PCB.
Then stick all the remaining joints of PVC body with super glue.
7
Testing
Finally testing the DIY Smart Solar Lamp.
It will automatically charged in Daylight with the help of solar panel and turns on the lamp automatically during night.
New users will also get some coupons while registering at JLCPCBvia this blue link.
Thank you for reading this guide, hopefully, this guide provides full steps to help you to create your ownDIY Solar Lamp.If you have any questions please post them in the comment section below.
