2The 3D Files
Although some may think I'm crazy, I have completely designed the Cyberdeck using Tinkercad. I know there are way better tools, but I am used to Tinkercad and considered it an additional fun challenge to just use a basic 3D design tool ;)
Here you can find the parts for the Cyberdeck - Top
Here you can find the parts for the Cyberdeck - Bottom
3The badly documented assembly process of the bottom part
1.) It all started with the assembly of the top-right router and the bottom-right Wifi & Network Analyzer Module
2.) The bottom-right Wifi & Network Analyzer Module (I have stripped the TP-Link WLAN Router like hell and used a lot of Hot-Glue)
3.) Next was the 12V Battery and its RFID / NFC cover
4.) Followed by all the Power Modules & Volt Meters, ...
5.) ... and a first test run
6.) Assembly of the modular "Boxes" part
6.) And the final status of the bottom case
