hinge_top_right_rev3.stl
Print 1x
Standard Tesselated Geometry -
14.43 MB -
10/03/2022 at 02:01
Download
hinge_base_left_rev3.stl
Print 1x
10.76 MB -
10/03/2022 at 02:01
Download
hinge_top_left_rev3.stl
Print 1x
14.68 MB -
10/03/2022 at 02:01
Download
hinge_base_right_rev3.stl
Print 1x
10.64 MB -
10/03/2022 at 02:01
Download
hex_foot_rev3.stl
Print 4x
4.27 MB -
10/03/2022 at 02:01
Download
top_edge_fill_derived_rev3.stl
Print 4x
506.35 kB -
10/03/2022 at 02:01
Download
corner_piece_bottom_rev3.stl
Print 2x
1.33 MB -
10/03/2022 at 02:01
Download
corner_piece_top_rev3.stl
Print 2x
1.57 MB -
10/03/2022 at 02:01
Download
faceplate_rev3.dxf
Cut 1x of 3mm Acrylic or other material.
AutoCAD DXF -
181.87 kB -
10/03/2022 at 02:01
Download
bottom_edge_fill_derived_rev3.stl
Print 4x
415.09 kB -
10/03/2022 at 02:01
Download
case_top_flatpattern_rev3.dxf
Cut 1x of 2.5mm Thick Aluminum and get bent.
AutoCAD DXF -
133.31 kB -
10/03/2022 at 02:01
Download
case_bottom_flatpattern_rev3.dxf
AutoCAD DXF -
137.86 kB -
10/03/2022 at 02:01
Download
bottom_plate_rev3.dxf
AutoCAD DXF -
103.68 kB -
10/03/2022 at 02:01
Download
computer_cover_rev3.dxf
Cut 1x of 3mm Acrylic or other material. Translucent recommended.
AutoCAD DXF -
91.95 kB -
10/03/2022 at 02:01
Download
battery_plate_rev3.dxf
AutoCAD DXF -
101.85 kB -
10/03/2022 at 02:01
Download
