Testing of the actual ASIC
02/21/2024 at 21:34 • 0 commentsI finally received the TinyTapeout board with the Zinnia+ MCU design!
I decided to use an RP2040 the exercise the I/O of the design. Since the code memory is external to the MCU, it needs to be emulated by a program on the RP2040.
Here is the output of the prime number generation program:
More documentation and code here: https://github.com/cpldcpu/tt02-mcpu5plus/tree/main/validation -
Improved Instruction Set Architecture: Zinnia+
09/07/2022 at 19:56 • 0 commentsPost-Tapeout-Regret version: When I implemented the primes example code I noticed some shortcomings of the instructions set architecture that could be easily fixed. The updated version is here on Github, but unfortunatly did not make it on the chip.
Changes
Three changes have been introduced:
Allowing the
NEGinstruction to upgrade the carry. This allows for an easy test for accu=0 or overflow duringINC/DECmacros. -
Modifying the
BCCinstruction to read part of the branch target address from the accu, if the iflag is set. This allows for much easier implementation of 8 bit branch target addresses. -
Removing
JMPAas it was deemed unnecessary with the modification above.
The resulting instruction set design reduces code size, improves execution speed and even reduces the number of macrocells in the design. A clear win-win.
Updated Instruction set
Macros using updated instruction set
Benchmark of normal vs. plus version
Testbench and Assembler
09/07/2022 at 16:34 • 0 commentsYou can find the cleaned up designfiles including testbench and assembler on Github.
I ported two program examples from my other processor designs: Fibonacci number calculation and a prime number search algorithm.
Fibonacci examples seem to be quite commonplace for minimal processor implementations. However, Fibonacci can be implemented on a machine without any decision making (branching). So, proving that an architecture is able to execute Fibonacci is possibly not a proof of Turing completeness. This is why I prefer the prime number search.The Fibonacci implementation is straightforward and shown below:
.=0 init: LDI 0 STA R0 ; a = 0 LDI 1 STA R1 ; b = 1 loop: LDA R1 STA R2 ; temp = b ADD R0 STA R1 ; b' = a + b LDA R2 STA R0 ; a = b OUT ; display b BCC loop idle: BCC idleThe testbench will show the output of the executed programs directly in the shell. In addition, a VCD file with waveforms is generated, which can be viewed with GTKWAVE or the WaveTrace plugin in VSCode.
The number in brackets shows the number of executed program cycles, the output shows the content of the accumulator when the "OUT" instruction in the machine code is executed.
; divisor=2; ; while (divisor<number) ; { ; test=-number; ; while (test<0) test+=divisor; ; if (test==0) return 0; ; divisor+=1; ; } ; return 1; number = R0 divisor = R1 allone = R7 .=0 start: LDI -1 STA allone LDI 2 STA number OUT ; first prime is 2 outerloop: LDI 2 STA divisor ;divisor = 2 LDI 1 ADD number STA number loop: LDA number ; test=-number; NEG innerloop: ADD divisor ; while (test<0) test+=divisor; BCCL innerloop ADD allone ; if (test==0) return 0; BCCL outerloop ; No prime LDI 1 ; divisor+=1; ADD divisor STA divisor NEG ; while (divisor<number) ADD number BCCL loop prime: LDA number ; Display prime number OUT JMP outerloop -
Design Description
09/06/2022 at 20:32 • 0 commentsTop level
The strict limitations on I/O do not allow implementing a normal interface with bidirectional data bus and separate address bus. One way of addressing this would be to reduce the data width of the CPU to 4 bit, but this was deemed to limiting. Another option, implementing a serial interface, appeared too slow and too complex.
Instead the I/Os were allocated as shown below.
The CPU is based on the Harvard Architecture with separate data and program memories. The data memory is completely internal to the CPU. The program memory is external and is accessed through the I/O. All data has to be loaded as constants through machine code instructions.
Two of the input pins are used for clock and reset, the remaining ones are reserved for instructions and are six bit in length. The output is multiplexed between the program counter (when clk is '1') and the content of the main register, the Accumulator. Accessing the Accumulator allows reading the program output.
Programmers Model
Besides simplifying the external interface, the Harvard Architecture implementation also removes the requirement to interleave code and data access on the bus. Every instruction can be executed in a single clock cycle. Due to this, no state machine for micro-sequencing is required and instructions can be decoded directly from the inst[5:0] input.
All data operations are performed on the accumulator. In addition, there are eight data registers. The data registers are implemented as a single port memory based on latches, which significantly reduced are usage compared to a two port implementation. The Accu is complemented by a single carry flag, which can be used for conditional branches.
Handling of constants is supported by the integer flag („I-Flag“), which enables loading an eight bit constant with two consecutive 6 bit opcodes.
The list of instructions and their encoding is shown below. One challenge in the instruction set design was to encode the target address for branches. The limited opcode size only allows for a four bit immediate to be encoded as a maximum. Initially, I considered introducing an additional segment register for long jumps, but ultimately decided to introduce relative addressing for conditional branches and a long jmp instruction that is fed from the accumulator.
Having both NOT and NEG may seems excessive, but the implementation was cheap on resources and some instruction sequences could be simplified.
No boolean logic instructions (AND/OR/NOT/NOR/XOR) are supported since they were not needed in any of my typical test programs.
The table below shows common instruction sequences that can be realized with macros.
Tim
