Here is the initial testing..
Some more explaining...
Trying out the new z axis ball screw.
Spindle feedback using the development encoder module which implements missing tooth index.
The power of Linuxcnc is shown with the project converting an Emco compact 5 lathe to true closed loop servos using the printer port.
