1Supplies
Get all the components ready.
2Get Your PCB Ready!
Talking about electronics.
- After making the circuit diagram I transformed it into a PCB design to produce it, to produce the PCB, I have chosen JLCPCB the best PCB supplier and the cheapest PCB provider to order my circuit. with the reliable platform, all I need to do is some simple steps which we will talk later.
- Related Download Files
- As you can see in the pictures above the PCB is very well manufactured and I’ve got the same PCB assembled with all the components that we want to use for our main board and all the labels and logos are there to guide me during the soldering steps. You can also download the Gerber file for this circuit from the download link below in case you want to place an order for the same circuit design.
3Place All the Components and Solder It Properly.
- Soldering the components.
- Refer to circuit diagram for connections.
4Soldering all PCB Components.
- Place all the through hole component and solder it to PCB.
5Connection of switches and battery.
- Make two holes in the circular PVC plate for the Push switches.
- Place the Push switches on the circular PVC plate and stick it with superglue.
- Make another hole for charging port in the same circular PVC plate.
- Connect all the remaining connection and solder it as shown (Refer to circuit diagram).
- Warning: Be Careful about polarity.
6Enclosing the Body.
- Then stick all the remaining joints of PVC body with super glue.
7Testing
Finally, testing the DIY Bicycle Lamp.
Place/fix it in your bicycle handlebar and done!
Your DIY Bicycle Lamp is now ready to lightup the path in darkness.
New users will also get some coupons while registering at JLCPCB via this blue link.
Thank you for reading this guide, hopefully, this guide provides full steps to help you to create your own DIY Bicycle Lamp. If you have any questions please post them in the comment section below.
ASHUMHRPROJECTS
