1.78 mA in sleep mode
03/16/2023 at 15:34 • 0 commentsI am able to get it running consistently and only draws 1.78 mA in sleep mode
Driving down power consumption
03/15/2023 at 16:28 • 0 commentsWorking on new python code to put the BC66 modem in PSM ( deepsleep) and sync up with the Raspberry Pi Pico to use machine.lightsleep. This reduces power consumption to an average of about 3 mA.
If an alarm goes off, it will wake up the board and send the alarm to the MQTT server
03/15/2023 at 16:26 • 0 commentsWorking on new python code to put the BC66 modem in PSM ( deepsleep) and sync up with the Raspberry Pi Pico to use machine.lightsleep. This reduces power consumption to an average of about 3 mA.
Boards are working
02/17/2023 at 18:33 • 0 commentsConnected the board to the pico, and tested it by sending mqtt message to an open hivemq broker. Its working great!
New boards
09/21/2022 at 14:21 • 0 commentsI just go the new boards. Due to supply chain issues some are missing parts. I will solder header pins on and see if I can talk to them from the PICO
