Neosegment - 7 Segment Display made with Neopixels
Creating a custom 7 segment display that can be driven with Arduino opens up some new possibilities.
The goal of this project is to create a modular component that works the same way as 7 segment display, with a few advantages over conventional 7 segment panels:
- Doesn't need additional components to drive the pixels
- Can change the color of display to any desired color
The build process for this project consists of the following components:
  • Create a 3D printable individual 7 segment display
  • Create schematics and PCB for individual display
  • Create Arduino Library to drive some number of 7 segment displays
Here's the latest update for this project:
SingleDigit25mmTall.stl
Second iteration of the 3D model, this time a lot slimmer and number is not as big
Standard Tesselated Geometry - 1.12 MB - 12/25/2016 at 09:58
Download
7Segment.kicad_pcb
Kicad PCB for the 7 segment display
kicad_pcb - 46.30 kB - 12/25/2016 at 09:52
Download
7Segment.sch
Kicad Schematics file for the 7 segment display
sch - 10.24 kB - 12/25/2016 at 09:52
Download
Single7SegmentDisplay.stl
3D printable 7 segment display for Neopixels
Standard Tesselated Geometry - 1.54 MB - 12/04/2016 at 00:46
Download
  • 7 × WS2812B LED
  • 7 × 0.1uf 0405 SMD Capacitor
  • 3 × Pin
  • First test of complete 7 Segment display
    Maksim Surguy12/25/2016 at 10:42 0 comments
    I had a preprogrammed NodeMCU (ESP8266) chip laying around with a FastLED library and test patterns already there.
    At this point, connecting Pin 2 to the Data Input of my PCB and connecting power pins should work unless I fry something.
    Here's what happened after I connected everything together:
    And then I was able to take a video of the display in its full glory, still running test patterns:
    It works in a beautiful way that is hard to describe or convey even with video, I think you have to see it in person to get the full effect.
    Next steps: optimizing the 3D model and PCB, making this modular and making 2 or 3 different sizes of the display!
  • Soldering components
    Maksim Surguy12/25/2016 at 10:31 0 comments
    After the circuit board was designed, printed on photo paper, transferred onto copper and etched, it was a quick process to solder 7 LEDs onto it. Soldering took about 15 minutes start to finish and I imagine this could be done much faster if you can use a reflow oven instead of hand soldering each component.
    I was impatient and soldered only 4 capacitors instead of 7 because I knew that this first prototype won't be chained together with other displays.
    Here is how the populated circuit board looks like:
    The lesson learned here was to create bigger pads for the Neopixels which will be taken care of in the next iteration of the PCB design.
    I don't know if I need bypass capacitor on each and every LED or if putting one 10uf cap per 7 Segments would suffice so if you know the answer to that question, please let me know!
  • Designing the schematics and the circuit board
    Maksim Surguy12/25/2016 at 10:20 0 comments
    Now that I have a proof of concept 3D printed model of the display, it is time to design a circuit board for 7 WS2812B LEDs that will light up the numbers on the display.
    This time I decided to use KiCad as an opportunity to learn proper circuit board building and after the schematics design is finished, I will finally put my new laser printer that I got on Cyber Monday to a good use to create a Printed Circuit Board (hint: toner transfer method)!
    The schematics design for this display is very simple and consist of only two kinds of components: WS2812B LEDs and capacitors. Each LED of this type has input and output pin so the series of LEDs need to be put together in a particular way: data output of one LED needs to feed into data input of another LED.
    Here's the design of the schematics in KiCad's EESchema before it was exported to PCBNew:
    In PCBNew, I placed the components at distances that correspond to my 3D printed model, then ran Freerouter to create a layout with minimum traces and no through hole connections. I then had to manually adjust a few pads and placements in order to use space efficiently. After about 3 tries of printing the circuit board and etching it (picture below), I was able to make one that worked.
    I've attached the circuit board schematics and the PCB design in Files section of this project.
View all 3 project logs
  • 1
    Step 1
    Print the 3D model
  • 2
    Step 2
    Create PCB
  • 3
    Step 3
    Solder 7 LEDs and 7 capacitors
View all 4 instructions
peter hartmann wrote 06/23/2019 at 17:52 point
Hey, nice work!  Have you seen my library?  https://github.com/h-c-c/Seven_Segment_Pixel  You can pull it in through the library manager in the Arduino IDE.
Xasin wrote 12/17/2018 at 08:33 point
This is looking really nice!
I like the idea of a compact 7-Segment display with a small PCB backside to hold everything together.
I have a small recommendation though: With the latest Prusa Slic3r version and a few small tweaks, I've had great success with "manual" multi material printing. That could look quite good for your project, if a diffusion layer is built in to the segment casing itself :D
Oh yeah, also, I hope your library can drive segments with two WS2812 per "dash", then people could use your code and my giant digit pieces >:D
