So I was wondering how best to arrange the #Tetrinsic's [gd0041] and decided on going for a vertical keyboard that sat in my lap (which is the current location of my not-so-temporary temporary keyboard as I write this very log). I soon determined that a 90 degree arm-to-arm angle was a good initial ball park estimation. I just didn't know how I was going to get that carved-out-of-marble shape, whilst still having some level of portability and aesthetic. It didn't have to fit in #Teti's [gd0022] compartement but I still wanted to be able to put it in a backpack nicely.
I was thinking of something that looked like a smaller, thinner version of Teti's overall shape and having the Tetrinsics unfold out from a vertical wall into a tented position. I thought that was too complex for what is essentially a not-so-temporary temporary Tetent, and Teti doesn't have any crisp low-poly corners in its design language.
The next idea was a cuboid but with the bottom face angled a few degrees for more comfortability. I noticed that the XYZ were approaching the same value and so I just made it a cube and really liked the inital look:
If I make this, and if one insists on calling Tetent a keyboard (even though there are no keys, and it's not a board), it could be the worlds second cube shaped keyboard. The first was this failed indegogo campaign I found when searching to see if there have been any other cube shaped keyboards.
Anyway, after watching their spaceship teleportation campaign video, I thought I'd make the renders look a bit more si-fi with the LED ring around it:
Initial stats:
- 86mm cubed
- 3 degree angle
- Finger2: -5
- Finger3: -8
- Finger4: -5
- Finger5: 0mm from surface
- Finger5 is also 10mm closer to the cube edge
