Keycaps arrived
11/12/2022 at 11:34 • 0 commentsI ordered keycaps to 3d print service 2 weeks ago and I have keycaps now. Below photo is keyboard with keycaps.
It seems like I have done all what I planned.
Create keycap
11/05/2022 at 11:25 • 0 commentsMy keyboard's pitch of key switch is 16mm by 16mm. This means there isn't producted keycap for my keyboard. Natural option recently is 3D print the keycaps.
There is some people published keycaps for low pitch keyboards at marketplace on https://make.dmm.com/, well-known 3D print service in Japan. e.g. YKNキーキャップセット(Chocスイッチ 15x15mmキーピッチ用) or Choc 向け 挟ピッチ16mm 薄型キーキャップ(50個).
I liked YKNキーキャップ but it doesn't contain enough keycaps for my keyboard. I also wanted to keycap same size as kailh mini choc keyswitch, 14.5mm×13.5mm. So I tried to create keycaps using FreeCAD.
My first attempt is applying chamfer to box on FreeCAD but it was boring.
I tried Loft tool found while searching for a way to create better model against sketches I draw roughly and it unexpectedly worked well.
Completed firmware
11/03/2022 at 13:03 • 0 commentsI think I finished writing firmware.
Since QMK dosen't support XIAO m0 (SAMD21), I wrote simple keyboard firmware on arduino and Adafruit TinyUsb.
Code is available on github: https://github.com/ktmizugaki/xiao-75-keyboard/tree/main/prog/
it may not be trivial to build the firmware as I am using unusual setup.
Implemented switches
10/23/2022 at 02:25 • 0 commentsSwitches bought from aliexpress arrived.
Implemented switches.
Quickly tested and all keys worked.
I got a light
10/19/2022 at 12:07 • 0 commentsMy board shines.
teru
