See it in action:
The display has two rows. "U" is the current filament usage in millimeters. "T" is the total filament usage from the beginning. There is one RESET button. A short click will reset the "U" counter to zero, which is useful for each new project. A double click will reset the "T" to zero which s useful when replace the filament rolls. Additionally, when the unit powered up, the user is able to choose the direction of the filament movement, i.e. forward or backward depending on the mounting position of the sensor unit by pressing the Reset button.
mircemk
Juan M. Casillas
Jaques Lopes Schroeder
Hello,
it seems that the VCC and GND Pins in the jpg file are wrong and should be swapped.
