The project uses a web page hosted on the 8266 to provide a WEB UI to lock and unlock a cat door. You can also activate the door with a button on the module itself. The design utilizes a 3D-printed chassis and rack and pinion to lock the door. Check out the videos below for full details
Hi Jason! I know you made this almost 2 years ago now, but I wanted to know, do you happen to know how much weight that motor can lift?
I've got a cat door that's flexible, so this wouldn't work entirely, but I'm thinking I could use the same process to lift and close the cover for that door instead.
I figure there's some ways to finagle it to attach, but just need a motor that can lift the door up or down.
