1Print STL files
Print the STL files found here: https://cults3d.com/en/3d-model/gadget/remote-cat-door-lock No supports should be required, I would suggest 100% infill around mounting holes if your slicer allows this but it is not imperative.
2Screw in the motor and driver.
Screw the stepper motor and driver board into the chassis. The wiring loom on the motor is quite long so I wrapped it around the motor a couple of times to keep things tidy. Plug this into the driver board.
3Install the 8266 controller.
Screw in the controller on the other side of the chassis.
4Install spur gear
Press the spur gear onto the stepper motor. This should take a small amount of pressure.
5Install the lower limit switch.
Solder your wires onto the switch and drop the switch down the rack gear shaft. Push the button down with something firm it should click into the bottom of the shaft. Thread the wires through the hole under the spur gear.
You can now drop in the rack gear into the position
6Install the remaining wiring between the motor controller and motor.
Install the motor controller and lower limit switch wiring as shown in the guide, Pay particular attention to the order of the wires for the motor.
You can also connect the lower limit switch. Note that the pin between the lower limit switch and the input for the limit switch is a 3.3v supply make sure you do not accidentally connect this switch across 3.3v and GND (don't ask how I know).
7Install ALT switch
The ALT switch is just an alternative switch to the web page switch. Connect two wires to the switch and run these back to the controller following the wiring guide above.
You may have to flex the lever a bit for the switch to pop into position.
8Install code.
Copy and paste the following code into the Arduino IDE. Update the AP name and password to match your needs.
90% of this code is not mine. For full details please see this great guide: https://randomnerdtutorials.com/esp32-esp8266-web-server-physical-button/
// Import required libraries #ifdef ESP32 #include <WiFi.h> #include <AsyncTCP.h> #else #include <ESP8266WiFi.h> #include <ESPAsyncTCP.h> #endif #include <ESPAsyncWebServer.h> #define STEPPER_PIN_1 0 #define STEPPER_PIN_2 4 #define STEPPER_PIN_3 5 #define STEPPER_PIN_4 16 int step_number = 0; int lowerLimitState =1; // Replace with your network credentials const char* ssid = "YOURAP"; const char* password = "YOURAP_PASSWORD!"; const char* PARAM_INPUT_1 = "state"; const int lowerLimit = 14; const int output = 2; const int buttonPin = 12; // Variables will change: int ledState = LOW; // the current state of the output pin int buttonState; // the current reading from the input pin int lastButtonState = LOW; // the previous reading from the input pin int driveUpTime = 1000; // how long the motor should drive up for int upperTime=0; // Create AsyncWebServer object on port 80 AsyncWebServer server(80); const char index_html[] PROGMEM = R"rawliteral( <!DOCTYPE HTML><html> <head> <title>Cat door lock</title> <meta name="viewport" content="width=device-width, initial-scale=1"> <style> html {font-family: Arial; display: inline-block; text-align: center;} h2 {font-size: 3.0rem;} p {font-size: 3.0rem;} body {max-width: 600px; margin:0px auto; padding-bottom: 25px;} .switch {position: relative; display: inline-block; width: 120px; height: 68px} .switch input {display: none} .slider {position: absolute; top: 0; left: 0; right: 0; bottom: 0; background-color: #ccc; border-radius: 34px} .slider:before {position: absolute; content: ""; height: 52px; width: 52px; left: 8px; bottom: 8px; background-color: #fff; -webkit-transition: .4s; transition: .4s; border-radius: 68px} input:checked+.slider {background-color: #2196F3} input:checked+.slider:before {-webkit-transform: translateX(52px); -ms-transform: translateX(52px); transform: translateX(52px)} </style> </head> <body> <h2>Tap to unlock</h2> %BUTTONPLACEHOLDER% <script>function toggleCheckbox(element) { var xhr = new XMLHttpRequest(); if(element.checked){ xhr.open("GET", "/update?state=1", true); } else { xhr.open("GET", "/update?state=0", true); } xhr.send(); } setInterval(function ( ) { var xhttp = new XMLHttpRequest(); xhttp.onreadystatechange = function() { if (this.readyState == 4 && this.status == 200) { var inputChecked; var outputStateM; if( this.responseText == 1){ inputChecked = true; outputStateM = "On"; } else { inputChecked = false; outputStateM = "Off"; } document.getElementById("output").checked = inputChecked; document.getElementById("outputState").innerHTML = outputStateM; } }; xhttp.open("GET", "/state", true); xhttp.send(); }, 1000 ) ; </script> </body> </html> )rawliteral"; // Replaces placeholder with button section in your web page String processor(const String& var){ //Serial.println(var); if(var == "BUTTONPLACEHOLDER"){ String buttons =""; String outputStateValue = outputState(); //buttons+="<h4>Output - GPIO 2 - State <span id=\"outputState\"></span></h4><label class=\"switch\"><input type=\"checkbox\" onchange=\"toggleCheckbox(this)\" id=\"output\" " + outputStateValue + "><span class=\"slider\"></span></label>"; buttons+="<h4><span id=\"outputState\"></span></h4><label class=\"switch\"><input type=\"checkbox\" onchange=\"toggleCheckbox(this)\" id=\"output\"><span class=\"slider\"></span></label>"; return buttons; } return String(); } String outputState(){ if(digitalRead(output)){ return "checked"; } else { return ""; } return ""; } void setup(){ // Serial port for debugging purposes Serial.begin(115200); pinMode(output, OUTPUT); digitalWrite(output, LOW); pinMode(buttonPin, INPUT_PULLUP); pinMode(lowerLimit, INPUT_PULLUP); pinMode(STEPPER_PIN_1, OUTPUT); pinMode(STEPPER_PIN_2, OUTPUT); pinMode(STEPPER_PIN_3, OUTPUT); pinMode(STEPPER_PIN_4, OUTPUT); // Connect to Wi-Fi WiFi.begin(ssid, password); while (WiFi.status() != WL_CONNECTED) { delay(1000); Serial.println("Connecting to WiFi.."); } // Print ESP Local IP Address Serial.println(WiFi.localIP()); // Route for root / web page server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){ request->send_P(200, "text/html", index_html, processor); }); // Send a GET request to <ESP_IP>/update?state=<inputMessage> server.on("/update", HTTP_GET, [] (AsyncWebServerRequest *request) { String inputMessage; String inputParam; // GET input1 value on <ESP_IP>/update?state=<inputMessage> if (request->hasParam(PARAM_INPUT_1)) { inputMessage = request->getParam(PARAM_INPUT_1)->value(); inputParam = PARAM_INPUT_1; digitalWrite(output, inputMessage.toInt()); ledState = !ledState; } else { inputMessage = "No message sent"; inputParam = "none"; } Serial.println(inputMessage); request->send(200, "text/plain", "OK"); }); // Send a GET request to <ESP_IP>/state server.on("/state", HTTP_GET, [] (AsyncWebServerRequest *request) { request->send(200, "text/plain", String(digitalRead(output)).c_str()); }); // Start server server.begin(); initilaize(); } void loop() { int buttonState = digitalRead(buttonPin); if (buttonState == LOW) { ledState = !ledState; } digitalWrite(output, ledState); if (ledState) { lockDoor(); upperTime=0; } } void lockDoor() { lowerLimitState=digitalRead(lowerLimit); upperTime=0; Serial.println("driveMotor"); while (lowerLimitState!=0) { lowerLimitState=digitalRead(lowerLimit); OneStep(false); delay(2); } delay(10000); while (upperTime!=driveUpTime) { upperTime++; OneStep(true); delay(2); } digitalWrite(STEPPER_PIN_1, LOW); digitalWrite(STEPPER_PIN_2, LOW); digitalWrite(STEPPER_PIN_3, LOW); digitalWrite(STEPPER_PIN_4, LOW); ledState = !ledState; } void initilaize() { lowerLimitState=digitalRead(lowerLimit); while (lowerLimitState!=0) { lowerLimitState=digitalRead(lowerLimit); OneStep(false); delay(2); } while (upperTime!=driveUpTime) { upperTime++; OneStep(true); delay(2); } digitalWrite(STEPPER_PIN_1, LOW); digitalWrite(STEPPER_PIN_2, LOW); digitalWrite(STEPPER_PIN_3, LOW); digitalWrite(STEPPER_PIN_4, LOW); } void OneStep(bool dir){ if(dir){ switch(step_number){ case 0: digitalWrite(STEPPER_PIN_1, HIGH); digitalWrite(STEPPER_PIN_2, LOW); digitalWrite(STEPPER_PIN_3, LOW); digitalWrite(STEPPER_PIN_4, LOW); break; case 1: digitalWrite(STEPPER_PIN_1, LOW); digitalWrite(STEPPER_PIN_2, HIGH); digitalWrite(STEPPER_PIN_3, LOW); digitalWrite(STEPPER_PIN_4, LOW); break; case 2: digitalWrite(STEPPER_PIN_1, LOW); digitalWrite(STEPPER_PIN_2, LOW); digitalWrite(STEPPER_PIN_3, HIGH); digitalWrite(STEPPER_PIN_4, LOW); break; case 3: digitalWrite(STEPPER_PIN_1, LOW); digitalWrite(STEPPER_PIN_2, LOW); digitalWrite(STEPPER_PIN_3, LOW); digitalWrite(STEPPER_PIN_4, HIGH); break; } }else{ switch(step_number){ case 0: digitalWrite(STEPPER_PIN_1, LOW); digitalWrite(STEPPER_PIN_2, LOW); digitalWrite(STEPPER_PIN_3, LOW); digitalWrite(STEPPER_PIN_4, HIGH); break; case 1: digitalWrite(STEPPER_PIN_1, LOW); digitalWrite(STEPPER_PIN_2, LOW); digitalWrite(STEPPER_PIN_3, HIGH); digitalWrite(STEPPER_PIN_4, LOW); break; case 2: digitalWrite(STEPPER_PIN_1, LOW); digitalWrite(STEPPER_PIN_2, HIGH); digitalWrite(STEPPER_PIN_3, LOW); digitalWrite(STEPPER_PIN_4, LOW); break; case 3: digitalWrite(STEPPER_PIN_1, HIGH); digitalWrite(STEPPER_PIN_2, LOW); digitalWrite(STEPPER_PIN_3, LOW); digitalWrite(STEPPER_PIN_4, LOW); } } step_number++; if(step_number > 3){ step_number = 0; } }
Once the code is loaded you will need to find the IP address. If you do not have access to your router the code will display the IP in the serial console.
9Testing
As long as the controller gets a wifi connection it should start to initialize by driving the rack gear down to the lower limit switch and then immediately drive up. If the unit does nothing check your wifi credentials.
If you find it does drive down but not up check the wiring for the limit switch. If the unit continuously drives up the wiring for the motor is probably back to front.
If the unit successfully initializes push the ALT button to check the rack drives down. It should stay down for 10 seconds then drive up again. You can alter the time it stays down by increasing or decreasing the `delay(10000)` in the code.
Browse to the IP address of the unit and attempt to lower the gear.
10Conclusion
As long as the above functions correctly you have been successful! I run my unit off a power brick. A 18650 will last about a day mainly due to the WiFi soaking up the power but I have recently found a trick to reduce this drag so may get a couple of days.
You could also easily add an RFID reader so the unit only unlocks for your cat.
