Wifi controlled stepper motor
Control a stepper motor over Wifi
Public Chat
This project uses the common 28BYJ-48 stepper motor and 8266 wifi module to lock and unlock a cat door.
The project uses a web page hosted on the 8266 to provide a WEB UI to lock and unlock a cat door. You can also activate the door with a button on the module itself. The design utilizes a 3D-printed chassis and rack and pinion to lock the door. Check out the videos below for full details
  • 1
    Print STL files
    Print the STL files found here: https://cults3d.com/en/3d-model/gadget/remote-cat-door-lock  No supports should be required, I would suggest 100% infill around mounting holes if your slicer allows this but it is not imperative.
  • 2
    Screw in the motor and driver.
    Screw the stepper motor and driver board into the chassis. The wiring loom on the motor is quite long so I wrapped it around the motor a couple of times to keep things tidy. Plug this into the driver board.
  • 3
    Install the 8266 controller.
    Screw in the controller on the other side of the chassis.
View all 10 instructions
mickeythedrone wrote 03/29/2024 at 03:30 point
Hi Jason! I know you made this almost 2 years ago now, but I wanted to know, do you happen to know how much weight that motor can lift?
I've got a cat door that's flexible, so this wouldn't work entirely, but I'm thinking I could use the same process to lift and close the cover for that door instead.
I figure there's some ways to finagle it to attach, but just need a motor that can lift the door up or down.
Tim Savage wrote 11/05/2023 at 13:25 point
Nice, I already have the same stepper and driver board. My partner is getting sick of the cat waking her up at 4:30am and wants a solution.  Was thinking of something along the same lines, doesn't need to be more complex than this.
I'll probably just use ESPHome for the firmware.
Dan Maloney wrote 11/02/2022 at 18:30 point
Hi Jason --
This is great -- so many of these critter-proofing projects try to over-solve the problem, with machine learning and such. I love that all you did here was solve the essential problem. Great stuff!
Wrote this up for the blog, should publish soon. Thanks for the tip!
jasonwinfieldnz wrote 11/02/2022 at 22:19 point
Thanks for the feedback Dan. I try to keep it simple so anyone can have a go.
