The display of the stopwatch is controlled according to different keys;
event is responsible for the display content;
loop is responsible for controlling the operation according to the condition of keys.
#include "stopwatch.h"
static uint32_t record[8];
static uint8_t id;
static bool flag_start;
static bool flag_pause;
static bool flag_reset;
static bool flag_update;
static bool flag_record;
static uint32_t time_pause;
static uint32_t time_pause_sum;
static uint32_t time_start;
static uint32_t time_stop;
static void init(void *data)
tmos_memset(record, 0, 8 * 4);
flag_start = false;
flag_update = false;
flag_record = false;
flag_reset = false;
flag_pause = false;
time_pause_sum = 0;
time_pause = 0;
id = 0;
static void dispMs(uint32_t ms)
char buffer[15];
uint16_t x, y;
// UG_FillFrame(0, 0, 128, 25, C_BLACK);
UG_FontSelect(FONT_12X20);
UG_SetBackcolor(C_BLACK);
UG_SetForecolor(C_SNOW);
snprintf(buffer, 15, "%02d:%02d:%03d", ms / 1000 / 60, ms / 1000 % 60,
ms % 1000);
uint16_t title_width = UG_GetStringWidth(buffer);
UG_PutString((LCD_W - title_width) / 2, 1, buffer);
static void dispRecord(uint8_t index)
char buffer[15];
UG_FontSelect(FONT_8X12);
UG_SetForecolor(C_DARK_GREEN);
snprintf(buffer, 15, "%02d:%02d:%03d", record[index] / 1000 / 60,
record[index] / 1000 % 60, record[index] % 1000);
UG_PutString(45, 28 + index * 12, buffer);
static void enter(void *data)
// insert code
UG_FillScreen(C_BLACK);
dispMs(0);
UG_DrawLine(0, 25, 128, 25, C_GREEN);
for (uint8_t i = 0; i < 8; i++)
UG_PutChar(i + '1', 10, 28 + i * 12, C_DARK_GREEN, C_BLACK);
UG_PutString(45, 28 + i * 12, "__:__:___");
manager_startEvent(222);
manager_setBusy(false);
static void event(void *data)
if (flag_update == true)
// 开始刷屏
uint32_t time_consume;
time_consume = millis() - time_start - time_pause_sum;
dispMs(time_consume);
if (flag_record == true)
record[id] = time_stop - time_start;
dispRecord(id);
id++;
if (id >= 8)
id = 0;
if (flag_reset)
flag_reset = false;
flag_start = false;
flag_pause = false;
time_pause_sum = 0;
time_pause = 0;
id = 0;
dispMs(0);
static void loop(void *data)
KEY_TYPE key;
key = HAL_KeyGet();
switch (key)
case KEY1_LONG:
manager_switchToParent();
break;
case KEY1_DOWN:
if (flag_start == false)
//first
time_start = millis();
flag_start = true;
flag_update = true;
else
if (flag_pause == false)
flag_record = true;
time_stop = millis() - time_pause_sum;
else
time_pause_sum = millis() - time_pause + time_pause_sum;
flag_pause = false;
flag_update = true;
break;
//pause
case KEY2_DOWN:
flag_pause = true;
time_pause = millis();
break;
//reset
case KEY3_DOWN:
flag_reset = true;
break;
default:
break;
static void quit(void *data)
// insert code
manager_stopEvent();
manager_setBusy(true);
