Electric skateboard built with custom 3D printed/Machined parts/leather parts, VESC, WiMote, Vanguard Deck.
Attempt 1 was with customer Arduino code/wiimote and a RC boat ESC. Forward was ok breaking.....Broken ESC. Moved to VESC
Attempt 2 loose wires around powered VESC.... shorted MCU
Attempt 3 1 Hot-air rework station, new MCU and some troubleshooting and it was good to go.
Currently the main issue is VESC is cutting out at full throttle. Have messed with current limits, voltage low limits, increased power caps still no solution. Next step is a VESC swap to see if that fixes the issue. TBD
