Completed!
12/03/2022 at 00:34 • 0 commentsSo - I finished coding up the firmware using an Arduino Nano. You can find it on github here: https://github.com/Pacmanfan/TurboPump
I took the time to make a nice box, gave it a power supply, button for simple on/ off activation and a RGB LED indicator for status.
I suspect that many other turbo pumps that have a single coil and hall sensor can use this firmware.
