Problem
Design an inexpensive circuit using easily available components to drive nixies. Modularity i.e. same circuit for each nixie desirable so that the number of digits can be flexible.
Previous solutions
Use the TTL 74141 IC or Soviet clones. This is a BCD to 1 of 10 line nixie driver. The problem is that these chips are getting harder to find all the time.
Use a BCD to 1 of 10 output IC such as the CD4028 driving 10 high voltage switching transistors. This IC is available and reasonably priced, but 10 discrete transistors and base resistors are needed.
Use a cheap microcontroller again driving high voltage switching transistors. Costs are similar to the previous solution but a MCU gives more flexibility.
Using a shift register that can handle high voltage on the outputs, such as the TPIC6B595 which is a version of the 74HC595 that has open collector outputs and can hold off 50V. It can also sink far more current than a nixie will need. Note that when switching a nixie, you don't need to hold off the full supply voltage, only the difference between the strike and sustain voltages. One problem is that the shift register handles 8 lines so 1¼ ICs are needed, which means the design won't be modular without wasting ICs.
Other specialised ICs I have seen in searches but which might be hard to get and become unobtainium at any time.
Schematic
Here is the circuit I developed.
The Ircon repurposing project #Repurposing an old nixie thermometer showed how to stack two levels of transistors so that less than 10 lines are needed to turn on a cathode. This was explained in the Don Lancaster RTL Cookbook, and partly in an online article on driving nixies with transistors. With 8 lines we can use a 4x4 matrix to drive up to 16 outputs. A 3x4 matrix for 12 outputs suffices. We use the 8th bit to drive the decimal point not catered for in the previous solutions and which has to be independent.
This requires more transistors than 1 of 10 decoders = more components and soldering. But what if the transistors are in SMD packages assembled by automation? They could be very cheap. Investigation showed that JLCPCB/LCSC offers the MMBT5551 NPN transistor with 160V breakdown voltage, far more than needed, in SOT-23 form factor for about a cent each. The base current limiting resistor is also SMD. They are driven by the widely available 74HC595 shift register in a SMD package. The board is modular and cascadable to any reasonable number of digits. The time to shift in the digits is negligible compared to the display refresh period and the output is latched with a single strobe signal. The nixies are statically driven, no multiplexing, which is problematic for nixies and low duty cycles.
We will need different board layouts for nixies with a different pinout or size. But this is true whichever driver solution is adopted. This means that if you have different nixies from mine, which are the Hitachi CD71, you need to adapt the board.
Digression: Actually the nixies I have are labelled AEC-9171 and were sold in the early 70s. No information about this model can be found on the Internet, which is not surprising as this was before the Internet. Here is an extract from the 2-page datasheet from the supplier which I have kept with the nixies all those decades. From a comparison of that and datasheets online, I concluded it was a rebranded Hitachi CD71 as the pinouts and dimensions match. Testing the nixies with a harness confirmed it, and that the nixies are still functional. The information in my datasheet isn't very useful as they are specified for multiplexing so I have gone with the CD71 data.
A special "font" is needed to drive a nixie from 8 bits of data, but a MCU takes this in its stride.
Two anode resistors in parallel are used to spread the heat dissipation. I intend to use a 12V to 170-200V boost converter for the anode supply. The HV rail is designed to daisy-chain too, like the LV rail, data, and control lines.
Fabrication
Although I had done some preliminary investigation into low cost PCB fabrication and assembly for a SMT version of the #3 line to 32 line output expander , I realised that this design was a better target for PCBA. So this is my first PCBA project and I am pleased with the results. I got 10 PCBs for about $2 each delivered. That should take care of the 6 CD71 nixies I have. Another nixie with a similar layout, and long leads, can be handled with a some crossing of the long insulated leads. Wonder what I can do with a lone nixie? A one-digit clock? Don't laugh, somebody already did this, by showing the digits in sequence. Setting it should be a challenge.
Assembly
Only 3 components need to be soldered, the 74HC595 shift register IC in SOP-16 package, and two TH anode resistors. I could have ordered the shift register for PCBA, but it costs more with the minimum order quantity stipulation, I already had many of those chips, and they are very easy to solder with the right technique.
Testing
After putting together 6 boards for the 6 nixies I connected up one to an Arduino running the following sketch.
Test shift register display with scrolling N digits
The initialisers for 'number' set N
#define DATA 2
#define CLOCK 3
#define LOAD 4
#define NIXIEFONT
#undef LOWON
#ifdef LOWON
#define OFFSTATE HIGH
#define ONSTATE LOW
#else
#define OFFSTATE LOW
#define ONSTATE HIGH
#endif
const byte segtable[] =
#ifdef NIXIEFONT // using shift register driver
{ 0x11, 0x12, 0x14, 0x18, 0x21, 0x22, 0x24, 0x28, 0x41, 0x42 };
byte number[] = { 0, 1, 2, 3, 4, 5, };
#else // 7 segment font
{ 0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d, 0x7d, 0x07, 0x7f, 0x6f };
byte number[] = { 0, 1, 2, 3, };
#endif
#define COLON 0x80 // top bit
#define DIGITS (sizeof(number)/sizeof(number[0]))
byte display[DIGITS];
void setup() {
// put your setup code here, to run once:
pinMode(DATA, OUTPUT);
pinMode(CLOCK, OUTPUT);
pinMode(LOAD, OUTPUT);
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(DATA, OFFSTATE);
digitalWrite(CLOCK, LOW);
digitalWrite(LOAD, LOW);
void writebyte(unsigned int i) {
for (byte mask = 0x80; mask != 0; mask >>= 1) {
digitalWrite(DATA, i & mask ? ONSTATE : OFFSTATE);
delayMicroseconds(10);
digitalWrite(CLOCK, HIGH);
void load() {
digitalWrite(LOAD, HIGH);
void writedigits(const byte *data) {
for (byte i = 0; i < DIGITS; i++)
writebyte(*data++);
load();
void loop()
for (;;) {
display[i] = segtable[number[i]];
writedigits(display);
digitalWrite(LED_BUILTIN, HIGH);
delay(250);
digitalWrite(LED_BUILTIN, LOW);
delay(250);
for (byte i = 0; i < DIGITS; i++) {
if (++number[i] > 9)
number[i] = 0;
The test program sequences from 0 to 9. This was taken in the ½ second it was showing 6. Here is the full sequence.
Finishing the project
One of my failings is that after I have satisfied myself that a design works, I lose interest and fail to finish the project. I finally chained 6 modular nixie boards together as originally planned. The demonstration video is at the top of this details page.
It was not without some hitches:
- Firstly I hate perfboard. Oh, did I mention that I hate perfboard? When I do the next version of the board with a different model of nixie, I will also make a motherboard base for the modular boards.
- Next when I tried the test program, I found that the order of the digits was reversed. I just had to edit the program to change the initial numbers.
- Then I found that the leftmost nixie didn't display 8 and 9. Inspection of the board showed that the SMD base resistor for the 8 and 9 driver transistor was missing. Whether this was due to it dropping out or not soldered by the fabrication plant I don't know. Fortunately I have some SMD resistors. It's 10k rather than the 22k specified, but this resistor value is not critical.
- The one problem I could not fix quickly was the last nixie would sometimes activate 2 cathodes at the same time. There may be a fault with this board. In any case the nixie in the position cannot display 5 because the wire for 5 cathode broke off. I may leave this digit blank in the final product.
Ken Yap
