Z80-2025-06-20.tar.bz2x-bzip - 9.32 MB - 06/21/2025 at 09:32 |
Capture d’écran de 2022-12-03 07-40-14.pngPortable Network Graphics (PNG) - 177.38 kB - 12/16/2022 at 09:35 |
Capture d’écran de 2022-12-11 21-43-39.pngPortable Network Graphics (PNG) - 47.16 kB - 12/16/2022 at 09:34 |
Capture d’écran de 2022-12-13 01-17-55.pngPortable Network Graphics (PNG) - 34.27 kB - 12/16/2022 at 09:34 |
Capture d’écran de 2022-12-08 04-34-47.pngPortable Network Graphics (PNG) - 119.54 kB - 12/08/2022 at 09:42 |
Capture d’écran de 2022-12-08 04-34-58.pngPortable Network Graphics (PNG) - 87.27 kB - 12/08/2022 at 09:42 |
Capture d’écran de 2022-12-08 04-35-10.pngPortable Network Graphics (PNG) - 83.47 kB - 12/08/2022 at 09:42 |
Z80.tar.bz2The Z80 software running on the microcontroller. It will support execution of Z80 codes with a modified libZ80 library. The loadIntelHex function works with interrupts, but with a limited rate transfer. See PV on linux.Download a hex file with: pv -L 500 myhexfile.hex > /dev/ttyUSB0 (or USB1 depending on your setup) application/x-bzip - 9.38 MB - 12/03/2022 at 09:53 |
libz80.tar.bz2A slightly modified libZ80 for executing Z80 code. The original is here:https://github.com/ggambetta/libz80. Modifications were made to generate fetch and interrupt acknowledge bus cycle in addition to the already existing memory and IO access. x-bzip - 4.84 MB - 12/03/2022 at 09:53 |
stm32f407_z80.kicad_schKicad schematicx-kicad-schematic - 968.38 kB - 12/03/2022 at 09:46 |
stm32f407_z80.kicad_pcbKicad PCBx-kicad-pcb - 114.78 kB - 12/03/2022 at 09:46 |
gerbers-stm32f407_z80.zipGerber files for production. No budge wire needed!Zip Archive - 20.28 kB - 12/03/2022 at 09:46 |
Jacques Pelletier
