On board USB UART not working?
12/05/2025 at 19:03 • 0 commentsI had problems with the USB UART (CH340G). It frequently disconnected under Linux.
I just looked into this these past weeks. It turned out that the USB connector became flaky and that was the cause for the frequent disconnects. I also suspected the chip wasn't supported, but a loopback test worked fine with minicom (while the connection lasted). So linux supports the CH340G. -
binary editor improvements
06/21/2025 at 09:27 • 0 commentsThe binary editor was a bit awkward to use. I simplified this and added the terminal's arrow keys to move around.
How to use:
like shown in the photos, the STM32F407GT6 board is plugged into a STM to Z80 adapter board.
This board makes the connection to the serial port of the STM board and a connector is available to connect an FTDI basic or similar USB to serial converter. Open a terminal at 115200 bauds N81, and set ANSI terminal.
There was a compilation error that was simple to correct. In Core/Src, there's a file sysmem.c. Edit it and add this include:
#include <sys/types.h>
Minor fix
12/13/2022 at 06:23 • 0 commentsA minor fix to display the status of the debugger: Step, Run or Halted.
Basic functionalities completed!
12/12/2022 at 02:38 • 0 commentsI completed the debugger: it can step, run until 'RET', run until PC = address, run continuously. You can also edit the registers between steps.
Importing symbols will be implemented later.
Source files available on Github
12/07/2022 at 16:21 • 0 comments -
Suggestions and features wanted
12/07/2022 at 15:12 • 0 commentsI'm currently writing the debugger part of the Z80 ICE. I would like to have suggestions and features that users would want.
-step
-step until return
-breakpoint (step until PC = breakpoint address)
More complex features to implement:
support for NMI and interrupts, (being able to step in these)
import symbol files from SDCC and Z88SDK
LibZ80 is working!
12/05/2022 at 01:37 • 0 commentsI just integrated the libZ80 and it now executes Z80 code!
I will make a easy to use debugger which can step, show disassembly, registers and stack.
To do: import symbol files
Some improvements already
12/04/2022 at 13:17 • 0 commentsAdjusted the bus cycles timing to be equivalent to those measured on a real Z80 at 4 MHz.
Done some improvements to the binary editor, it's a bit easier to use and there's now a help on screen.
The Intel Hex loader now works if we send bytes slowly enough. On linux, I use the command: "pv -L 10 myhexfile.hex > /dev/ttyUSB0", which transmit 10 bytes/sec.
I will try to implement interrupt or DMA on the serial port.
Jacques Pelletier
