1TM8211 and PT8211 I2S audio DAC(16bit)
Tested with above two 16bit I2S audio DAC and working fine!
2MAX98357 DAC and CLASS-D AMPLIFIER
Tested with I2S DAC+AMPLIFIER using MAX98357 IC.
Since it is a MONO output, you need 2 boards to get stereo output. Please refer to configuration and gain details from the manufacturer site.
3UDA1334 (NXP) I2S DAC
4PCM5100A stereo DAC + headphone amplifier
Features
- PCM5100A stereo DAC
- PAM8908JER stereo headphone amp
- 3.5mm stereo headphone jack connector
- 3.5mm stereo line out jack connector
- Switch to adjust headphone amp gain (low / high)
- Dimensions: approx 53mm x 29mm x 11mm (L x W x H, including headers and audio jacks)
Tested with the above DAC and working fine for line out and headphone
5PCM5102A I2S DAC (Ti)
Tested with the above DAC and working fine.
mit41301
