coroplast roof template.pdf
Shows dimensions of the coroplast roof
Adobe Portable Document Format - 344.03 kB - 12/15/2022 at 03:33
Preview
Tripod mount.stl
3D Print this part in PETG and place a 1/4-20 nut in it to make a tripod mount.
Standard Tesselated Geometry - 624.20 kB - 12/15/2022 at 02:36
Download
holesaw 20 mm.stl
3D Print this holesaw in PETG teeth side up.
Standard Tesselated Geometry - 66.59 kB - 12/14/2022 at 03:20
Download
test mount4.stp
Step file for the elastic mount.
stp - 77.55 kB - 12/14/2022 at 02:53
Download
Capsule holder 22mm.stp
Step file for Capsule holder.
stp - 36.39 kB - 12/14/2022 at 02:53
Download
foam stencil.pdf
Document showing the dimensions of the foam stencil, equivalent to the urethane sponge profile.
Adobe Portable Document Format - 1000.71 kB - 12/14/2022 at 02:51
Preview
foam cutting layout.pdf
Document showing dimensions of the styrofoam parts and how to cut them from a 2fx2ftx 1 in pink exterior construction styrofoam.
Adobe Portable Document Format - 1011.84 kB - 12/14/2022 at 02:51
Preview
test mount4.pdf
Document showing the elastic test mount.
Adobe Portable Document Format - 409.40 kB - 12/14/2022 at 02:51
Preview
foam stencil.stl
A stencil used to mark the urethane sponges. 3D print in PLA
Standard Tesselated Geometry - 12.97 kB - 12/14/2022 at 02:51
Download
Capsule holder 22mm.stl
Holds elastic mount which holds capsule. 3D print in PETG.
Standard Tesselated Geometry - 581.92 kB - 12/14/2022 at 02:50
Download
test mount4.stl
Elastic mount for the capsule. 3D print in a flexible filament (TPE)
Standard Tesselated Geometry - 321.57 kB - 12/14/2022 at 02:50
Download
mic board v1.0.sch
Eagle CAD Schematic file
sch - 685.29 kB - 12/13/2022 at 03:57
Download
mic board v1.0.brd
Eagle CAD Board file
brd - 55.72 kB - 12/13/2022 at 03:57
Download
mic board v1.0BOM.txt
Bill of Materials for the circuit board
plain - 678.00 bytes - 12/13/2022 at 03:57
Download
