Add with Carry
To date I have used plain and simple ADD with my DIY CPUs. ADC (i.e. add with carry) is useful for multi byte (nibble) addition as the carry is automatic. The downside is that the humble counter does not work, it skips 0. This can be fixed of course.
Here is the old counter using ADD:
20 LOAD 0 ; CLEAR ACC
A0 STORE MEM[0] ; SAVE TO MEM[0]
AF STORE MEM[F] ; OUTPUT
01 ADD 1 ; INCREMENT ACC
82 JNC 2 ; JUMP ON NOT CARRY
00 ADD 0 ; CLEAR CARRY
82 JNC 2 ; JUMP UNCONDITIONALLY 2
On on overflow you need to clear the carry so that the next JNC is an unconditional jump.
Here is the new counter using ADC:
00 ADC 0 ; CLEAR CARRY 20 LOAD 0 ; CLEAR ACC A0 STORE MEM[0] ; SAVE TO MEM[0] AF STORE MEM[F] ; OUTPUT 01 ADC 1 ; INCREMENT ACC 82 JNC 3 ; REPEAT 00 ADC 0 ; CLEAR CARRY 82 JNC 2 ; JUMP UNCONDITIONAL 2
So on overflow you need to both clear the carry and clear the accumulator.
Converting the ALU from ADD to ADC involves linking the Carry signal from the Control unit to the Carry In on the Adder in the ALU unit:
For completeness here is the Control unit:
The carry logic holds the carry (CY) until the next ADC instruction.
Multi-Nimble Arithmetic
Before moving on I tested an 8 bit counter using ADC:
00 ADC 0 ; CLEAR CARRY 20 LOAD 0 ; CLEAR ACC A0 STORE 0 ; CLEAR MEM[0] // LOW NIMBLE A1 STORE 1 ; CLEAR MEM[1] // HIGH NIMBLE AF STORE F ; CLEAR OUTPUT // LOW NIMBLE LOOP: C0 READ 0 ; PRESET ADDR TO MEM[0] 30 LOAD 0 ; LOAD LOW NIMBLE 01 ADC 1 ; INCR LOW NIMBLE A0 STORE 0 ; SAVE LOW NIMBLE AF STORE F ; OUTPUT LOW NIMBLE C1 READ 1 ; PRESET ADDR TO MEM[1] 31 LOAD 1 ; LOAD HIGH NIMBLE 00 ADC 0 ; ADD CARRY TO HIGH NIMBLE A1 STORE 1 ; SAVE HIGH NIMBLE JUMP LOOP: 00 ADC 0 ; CLEAR CARRY 85 JNC 5 ; UNCONDITIONAL JUMP
The ADC does not specifically need the JNC instruction.
The above code is 16 bytes long. A pretty strong justification for a 32 (or more) byte PROM system.
AlanX
agp.cooper
