Even if you're a beginner you'll be able to build this, with a little bit of work and dedication. You can watch the whole build series on my youtube channel: https://www.youtube.com/@coreWeaver
There will be 6 or 7 parts in total for this series and I'm gonna walk you through the whole design process, explaining the principle, starting with the block schematic, then showing you the electrical schematic and the pcb, soldering and testing the board, writing the software, designing, printing and building the case and then assembling everything into a finished product.
First part of the series (Intro, Features, Block Schematic):
Second part is now uploaded (i2C Level Translator, Parts, Schematic and PCB):
Part 3 (How to draw graphics on a char LCD) is available:
Part 4 (Board soldering and the Software) is online:
Thanks for all your positive feedback and support ! You guys rock !!
Part 5 (Designing the Case and the Assembly process) is now uploaded. You can watch it here:
Don't forget the Giveway at the end of this series. You can win 5 copies of the PCB for this project.
Stay tuned !
Part 6 (Testing, Explaining the functions) will shortly follow !
core weaver
oshpark
Roberto Innocenti
AVR
Miguel Tomas
