LampSoundSensor.pySimple, straightforward MicroPython code for using a sound sensor with your lamp board.py - 1.63 kB - 06/11/2025 at 18:30 |
LampMotionSensor.pypy - 1.61 kB - 06/11/2025 at 18:18 |
LampButton.pypy - 1.74 kB - 06/11/2025 at 18:18 |
PCB Lamp Workshop - Controller Board v3.1.stepSTEP file with grove/crowtail connectorsstep - 6.83 MB - 02/28/2024 at 19:24 |
PCB Lamp Workshop - Square.stpSTEP filestp - 1.50 MB - 04/26/2023 at 00:27 |
PCB Lamp Workshop - Line.stpSTEP filestp - 1.36 MB - 04/26/2023 at 00:27 |
PCB Lamp Workshop - Horseshoe.stpSTEP filestp - 1.85 MB - 04/26/2023 at 00:27 |
PCB Lamp Workshop - Circle.stpSTEP filestp - 1.99 MB - 04/26/2023 at 00:27 |
PCB Lamp Workshop - Controller and Lamp Board Outlines v3.dxf2D PCBA's in DXF file formatAutoCAD DXF - 4.19 MB - 02/29/2024 at 22:49 |
PCB Lamp Workshop - Controller and Lamp Board Outlines v3.1.ai2D PCBA's in Adobe Illustrator filepostscript - 345.22 kB - 02/28/2024 at 21:23 |
91290A013_Alloy Steel Socket Head Screw.STEPSocket head screws work better because there is not a lot of space for mounting holes on the boards.https://www.mcmaster.com/91290A013/ step - 425.34 kB - 04/26/2023 at 01:02 |
91290A013_Alloy Steel Socket Head Screw.PDFSocket head screws work better because there is not a lot of space for mounting holes on the boards.https://www.mcmaster.com/91290A013/ Adobe Portable Document Format - 134.61 kB - 04/26/2023 at 01:02 |
90592A075_Steel Hex Nut.STEPhttps://www.mcmaster.com/90592A075/step - 243.57 kB - 04/26/2023 at 01:02 |
90592A075_Steel Hex Nut.PDFhttps://www.mcmaster.com/90592A075/Adobe Portable Document Format - 102.61 kB - 04/26/2023 at 01:02 |
Data Sheet - Raspberry Pi Pico W.pdfRaspberry Pi Pico W documentation.Adobe Portable Document Format - 18.84 MB - 03/03/2023 at 20:39 |
Data Sheet - 987650-6631.PDFFlat flex (ribbon) cable data sheet.We are using the 6" OR 10" CABLE (FFC/FPC 6POS 1MM) https://www.digikey.com/en/products/detail/molex/0982670211/3469487 Adobe Portable Document Format - 913.87 kB - 03/03/2023 at 20:33 |
Data Sheet - WS2812B.pdfRGB LED's data sheet.Adobe Portable Document Format - 347.03 kB - 03/03/2023 at 20:33 |
Data Sheet - QRE1113-D.PDFMiniature Reflective Object Sensor data sheet.Adobe Portable Document Format - 328.92 kB - 03/03/2023 at 20:33 |
Optical_Sensor_v2.pyx-python - 1.69 kB - 03/07/2024 at 02:59 |
Supplyframe DesignLab
