Prensa de banco impresión 3D
Prensa de banco para impresión 3D. Modelo simple con 115 mm de apertura máxima.
0 followers
This proyect is a 3D printed bench vise. This bench vise has a maximum oppening of 115 mm. It's function is to be fitted at the side of a desk and has the ability to hold objects in place.
Este proyecto de impresión 3D es una prensa de banco. Esta prensa de banco tiene un apertura máxima de 115 mm. Su función es conectarse al borde de una mesa y poder sostener objetos en el lugar.
This 3D printed bench vise has a lot of exchangeable parts which can be modified by the user or replaced in case of a failure or  breaking.
The printing parameters of this 3D printing are as follows:
  • Standard resolution: 0.2mm
  • Infill: 15% triangles
  • Wall thickness: 0.8 mm
  • Wall line count: 2
  • Print speed: 50-60 mm/s
  • Total printing time: 31h 51min
  • Total weight: 258g
Parts:
1) Body
Printing time: 12h 52min
Weight: 108g
2) Base
Printing time: 4h 48min
Weight: 44g
3) Wall
Printing time: 2h 12min
Weight: 21g
4) Face x2
Printing time: 2h 33min
Weight: 23g
5) Pin
Printing time: 1h 8min
Weight: 8g
6) Slider
Printing time: 1h 35min
Weight: 15g
7) Screw 1
Printing time: 4h 12min
Weight: 24g
8) Screw 2
Printing time: 2h 31min
Weight: 15g
tornillo 1.stl
Standard Tesselated Geometry - 1.59 MB - 12/22/2022 at 22:19
Download
tornillo 2.stl
Standard Tesselated Geometry - 838.56 kB - 12/22/2022 at 22:19
Download
cuerpo.stl
Standard Tesselated Geometry - 52.04 kB - 12/22/2022 at 22:19
Download
base.stl
Standard Tesselated Geometry - 95.39 kB - 12/22/2022 at 22:19
Download
pasador.stl
Standard Tesselated Geometry - 15.71 kB - 12/22/2022 at 22:19
Download
View all 9 files
  • 1 × Body
  • 1 × Base
  • 1 × Wall
  • 1 × Slider
  • 1 × Pin
View all 9 components
  • 1
    Step 1
    First, the base is attached to the body with two screws that go into the holes in the base.
  • 2
    Step 2
    Then the slider is inserted into the body together with the pin. The pin is attached by two small screws to the body.
  • 3
    Step 3
    Then screw 1 is passed through the pin and screwed to the wall component.
View all 5 instructions
Rich text editor
