1Step 1
First, the base is attached to the body with two screws that go into the holes in the base.
2Step 2
Then the slider is inserted into the body together with the pin. The pin is attached by two small screws to the body.
3Step 3
Then screw 1 is passed through the pin and screwed to the wall component. -
4Step 4
Once the components are placed, the faces are added to the wall and to the body.
5Step 5
After this the only step that is left is to attach the vise to a table with the screw n°2.
