The Little Red Devil is built of several parts:
1. An amplifier proper - a class A single-ended EL84 / 6BQ5 amp (in ultralinear circuit) with a E88CC / 6DJ8 / 6922 input stage
2. Control circuit with an ATTiny45 microcontroller, a motor driver and an infrared receiver working with a RC-5 remote control
3. An input selector relay and a motorized volume pot
4. A ready-made Bluetooth audio interface
5. A separate power supply with two low voltage transformers wired back to back
Its output power (tested with used and pretty worn tubes I had in my lab) is 2 watts, decent for an UL single ended EL84 amp. Enough to rock the place :).
Keri Szafir
roberts.trops
smartroad
Quin
FiveseveN
Very interesting project, and I am curious why the E88CC is "in parallel"! The EL84 was known to be used in guitar amplifiers as well (Trainwreck amps).
Looking forward to the next project :)
