Keritech "Little Red Devil" Single-Ended EL84 Amp
A single-ended tube stereo amplifier with a modern technology twist
This amplifier, built in 2022, is a class A single-ended EL84 design built with vintage parts and a separate power supply. Its owner wished to have an inexpensive amp with a remotely controlled volume pot and a Bluetooth audio interface.
The Little Red Devil is built of several parts:
1. An amplifier proper - a class A single-ended EL84 / 6BQ5 amp (in ultralinear circuit) with a E88CC / 6DJ8 / 6922 input stage
2. Control circuit with an ATTiny45 microcontroller, a motor driver and an infrared receiver working with a RC-5 remote control
3. An input selector relay and a motorized volume pot
4. A ready-made Bluetooth audio interface
5. A separate power supply with two low voltage transformers wired back to back
Its output power (tested with used and pretty worn tubes I had in my lab) is 2 watts, decent for an UL single ended EL84 amp. Enough to rock the place :).
LittleRedDevil_RC.ino
x-arduino - 1.90 kB - 01/06/2023 at 00:50
Download
  • She's Lost Control Again? IR Remote and Microcontroller Shenanigans
    Keri Szafir01/06/2023 at 16:26 0 comments
    It was Monday when I bought a RC-5 remote for the Little Red Devil and was doing final tests on the amp, and to my disappointment, the remote control didn't work. Of course I wouldn't ship a non-functional amp, so I took a deep dive and checked what was going on... The relay and motor control outputs worked fine, there were pulses visible on a scope when I tested the IR sensor's output. So, was the code faulty? I looked into reading the RC-5 remote control commands, managed to decode them with an Arduino but not with the ATTiny45 microcontroller I built the board around. Why? It took me a few days to close in on the problem. First I thought it was I/O ports being assigned some special function rather than being usable as GPIO pins, but I could use any of them for controlling a LED, no problem.
    At some point I noticed that whenever I tried to flash a LED, it would shine a lot longer than it was supposed to. 50ms should be a really short pulse, right? Right... and yet I saw a LED shine for half a second or so. The timing was clearly off. Time to read into the microcontroller's fuse bit configuration and see if something was wrong there, and it turned out my chip's fuse bit config wasn't the same as default here: http://eleccelerator.com/fusecalc/fusecalc.php?chip=attiny45&LOW=6A&LOCKBIT=FF which was 0x6a for the lower fuse, and I had 0x62. Stupid as I am, I reprogrammed the chip to 0x6a, locking myself out of it, because now it expected an external crystal oscillator on pins 3 & 4 in order to work. So, off to a parts store, grab a crystal and two caps. Done. Restored 0x62. Problem persisted. Then, oh well... what if I disable the CLKDIV8 bit for frequency down-scaling? I did, and I tested the chip, and it was waaaaaay more realistic timing-wise, what was supposed to be 50ms pulse lasted a lot shorter than before, closer to what I would expect. Then, I uploaded the proper remote control code, tested it and tadam! It worked. Both the input selection and volume control. Winner winner, chicken dinner. The last thing I did was adding some code to store the last input selection relay state in ATTiny's built-in EEPROM, so that whenever you turn the amp off and on again, it would restore the previous selection rather than having to set it every time. The remote control is working fine now.
  • Little Red Devil on Youtube
    Keri Szafir01/02/2023 at 14:47 0 comments
    Before shipping, I made two videos on this creation:
    Fitst, the overview of the internals, schematics... and final assembly too:
    Then, there's the story of how I made it and what design challenges I had:
  • Finished!
    Keri Szafir01/01/2023 at 22:58 0 comments
    I built this amp on an extremely limited budget, having to make do with what I had in my lab (vintage parts), the cables, connectors, audio pot and enclosure from my customer, and secondhand vintage output transformers. He once mentioned he'd be tempted to make it red... while I already had painted the enclosure. Great minds think alike, it seems. I decided to make an amp that not only sounds nice, but also looks lovely, that's why I went to extra lengths with the internal construction to make as few holes in the enclosure as possible, and used an extra box to house the output transformers and control circuit board. While the pot control and Bluetooth interface were customer's wishes, I treated them as an additional engineering challenge, looked into doing that and I did... An interesting additional challenge for me - to avoid drilling holes in the enclosure, but still have a possibility of adding a remote (which normally would be done by putting a jumper on for powering up the controller), I used a reed switch from an old telecom relay. Putting a magnet over it before switching the amp on will throw the microcontroller in the programming mode, allowing the user to define the remote control buttons for volume up, volume down and input selection.
    After several months of coping with depression and anxiety, which means I rarely had energy to go on and my progress slowed, I finished the build, tested and debugged it, put it together, drew the schematics and made documentation, YT video included :).
View all 3 project logs
Will wrote 05/17/2023 at 22:23 point
Very interesting project, and I am curious why the E88CC is "in parallel"! The EL84 was known to be used in guitar amplifiers as well (Trainwreck amps).
Looking forward to the next project :)
Daniel G. Stephens wrote 01/06/2023 at 04:36 point
A lovely work of art. Well done.
Keri Szafir wrote 01/06/2023 at 07:56 point
Thanks! :)
Michael Zee wrote 01/03/2023 at 20:22 point
First of all, I don't know that you could have chosen a cooler name for the amp. 👌
 I love the external power supply, best thing for me though, it was created out of parts you already had. That's pretty bad ass! 👍👍
Keri Szafir wrote 01/04/2023 at 08:29 point
There's a lot of vintage parts kicking around in my lab since 2000s, not really viable for commercial amp making, but will last me a lifetime of doing projects :)
