[19-Feb-2023] Mount USB Adapters and SBCs on Acrylics Boards
02/20/2023 at 02:43 • 0 commentsJust simply drill the holes on some very old acrylics boards and mount those PCBs on. It's for protection and taking out easily.
[11-Feb-2023] Mount 30 SBC together
02/13/2023 at 13:36 • 0 commentsYeah! I find the last piece of my 30 SBC, mounted them together with hexagonal brass positioning column.
( M3 x 20mm column x 4mm screw )The 4mm screw is enough, but it's almost too short. 6mm would be better.
[12-Jan-2023] Test async to send command as fast as possible
01/12/2023 at 08:16 • 0 commentsTest async to send command to cameras as fast as possible
- Left-hand side is flask act like SBC receiving POST json data (localhost)
- Right-hand side is async to sending commandReferencing: Andrew Zhu - Send HTTP Requests As Fast As Possible in Python
https://python.plainenglish.io/send-http-requests-as-fast-as-possible-in-python-304134d46604?gi=a6c8e8786491 -
[12-Jan-2023] Server UI Frontend Test
01/12/2023 at 03:52 • 0 commentsTesting for Server UI Frontend (bootstrap, jquery, jquery.gridstrap)
Backend python pending
[11-Jan-2023] Prepare the deployment (Hardware)
01/12/2023 at 01:47 • 0 commentsTidy up and check some hardware for the 30 cameras deployment:
- Sony Cameras, more than 30, just in case
- 29 SBC, orange pi zero2 (1gb) + 16gb micro SD + Ubuntu (oh.. there are 29 only, have to find the missing one...)
- 8 x 4 port USB adapters + 30 USB Type C Cables (DIY USB cable is easy but 30...um, maybe next time)
- Twelve 8v 5a power adapter for cameras (🤔where are the fake batteries)
- Network, Router + Switch + Wireless AP + Infinity RJ45 & Cat5e
[8-Jan-2023] Progress: ​Control one camera from my Mac
01/09/2023 at 04:38 • 0 commentsProgress: Control one camera from my Mac with following items, not yet deploy to the SBC yet:
- Shutter speed (with fixed values, not yet get from the Camera API)
- F Number (with fixed values, not yet get from the Camera API)
- ISO (with fixed values, not yet get from the Camera API)
- White Balance (with fixed values, not yet able to add in the UI)- Trigger Shutter Release
- Trigger Half Shutter Button to lock everything
- Zoom In and Out (not yet show the zoom value after zoom)
- Set AF point by clicking on the LiveView screen
- Rotate the LiveView as well as fix the coordinate of focus (in case when the camera is rigged vertically or upside down)
https://github.com/liuaddie/vfx_cams/commit/fdf12d8d617b98a3c31306ee975335bea8b723cb
Some issues and details are still pending to implement for the controller part. But I am trying to ignore them first, and do a quick deployment to all SBCs to get an overview. So the SBCs should be able to auto sync the scripts after I updated the scripts, otherwise I have to do it one by one. The first method in my mind would be
- git pull
- install requirement
- run the controller script
every time when the SBC is started. -
[01-Jan-2023] Sony NEX5T Camera Power Current Test
01/05/2023 at 08:54 • 0 commentsHappy New Year~
Observe: 0.7A for peak
Conclusion: 1A is enough
Further: Use a 5A adapter to power 2-3 cameras -
[23-Dec-2022] Touch Focus Test
01/05/2023 at 05:37 • 0 commentsUse js/jquery got mouse click position on the liveview ➤ send position to python flask and pysony for sending command to the camera
[20-Dec-2022] UI Draft of Control Panel
01/05/2023 at 05:37 • 0 commentsUse jquery.gridstrap to implement "dragging cameras" function, it's for earlier to preview live feeds when all cameras are connected.
[19-Dec-2022] Begin Again
01/05/2023 at 04:47 • 0 commentsMove the git from private to public:
Some old tests and prototypes:
(Process) Automatic Photogrammetry with 12 Cams + DIY Motorized Turntable #realitycapture
https://youtu.be/NS14tNXzuHQ
(Result) Automatic Photogrammetry with 12 Cams + DIY Motorized Turntable #realitycapture
https://youtu.be/sHqS5uZzXiM
4 Sony Cameras trigger by Python
https://youtu.be/OhsvxAv73Pg
Test Remote Control NEX5R with Python + OpenCV
https://youtu.be/TwHIBRGk2Mw
Auto Servo Rotate and NEX5R Trigger Test
